Ga door naar hoofdinhoud
Kenmore 110 Series Washing Machine Water Pump Replacement
Wat je nodig hebt
  1. Kenmore 110 Series Washing Machine Water Pump Replacement, Water Pump: stap 1, afbeelding 1 van 1
    • Unplug the washing machine!
    • Carefully lay washing machine on its back.
  2. Kenmore 110 Series Washing Machine Water Pump Replacement: stap 2, afbeelding 1 van 3 Kenmore 110 Series Washing Machine Water Pump Replacement: stap 2, afbeelding 2 van 3 Kenmore 110 Series Washing Machine Water Pump Replacement: stap 2, afbeelding 3 van 3
    • Carefully remove both wire harnesses connected to the pump.
    • Squeeze and pull back hose clamp.
    • Twist drain hose off of pump.
    • Using a 1/4" socket wrench, remove the three mounting screws.
    • Pull the pump out of place.
    • Pulling the pump away takes a little force.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Robert Trout
1.234 Reputatie
5 handleidingen geschreven
Cal Poly, Team 15-43, Forte Fall 2012 Lid van Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Leden
11 handleidingen geschreven
9 opmerkingen
please provide info on how to test the water pump once it's removed...
Oscar Ramos - Antwoord
The instructions say nothing of the pulley belt and wheel.
I'm looking to work on a 110. 81080100
and
I have read that transmission fluid leaks out when the washer is on its side.
Is there a way to temporarily plug it?
thomas - Antwoord
My clothes are still really wet.
Tracy Schultz - Antwoord
Washer doesn't move doesn't do any thing it just hummus won't drain water
Hector Rios - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 73
Afgelopen 30 dagen: 341
Altijd: 58,757
