Ga door naar hoofdinhoud
Kenmore 110 Series Washing Machine Electronic Control Replacement
Wat je nodig hebt
  1. Kenmore 110 Series Washing Machine Electronic Control Replacement, Electronic Control: stap 1, afbeelding 1 van 1
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Electronic Control Replacement: stap 2, afbeelding 1 van 3 Kenmore 110 Series Washing Machine Electronic Control Replacement: stap 2, afbeelding 2 van 3 Kenmore 110 Series Washing Machine Electronic Control Replacement: stap 2, afbeelding 3 van 3
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Electronic Control Replacement: stap 3, afbeelding 1 van 2 Kenmore 110 Series Washing Machine Electronic Control Replacement: stap 3, afbeelding 2 van 2
    • Carefully remove the three wire harnesses.
    • With a phillips head screwdriver, remove the three mounting screws.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Robert Trout
1.234 Reputatie
5 handleidingen geschreven
Cal Poly, Team 15-43, Forte Fall 2012 Lid van Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Leden
12 handleidingen geschreven
3 opmerkingen
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
R Snagg - Antwoord
I am having the same problem. Did you ever find a fix?
Paul Bennett -
Did anyone find a fix for this problem?
Ron Rafe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 157
Altijd: 29,317
