Ga door naar hoofdinhoud
Katadyne Hiker Water Filter Cleaning
Wat je nodig hebt
  1. Katadyne Hiker Water Filter Cleaning, Katadyne Hiker Water Filter Cleaning: stap 1, afbeelding 1 van 1
    • Remove the "snap fit" guard by pulling directly away from the filter body.
  2. Katadyne Hiker Water Filter Cleaning: stap 2, afbeelding 1 van 1
    • Remove the pump handle by pulling it completely out of the shaft.
  3. Katadyne Hiker Water Filter Cleaning: stap 3, afbeelding 1 van 3 Katadyne Hiker Water Filter Cleaning: stap 3, afbeelding 2 van 3 Katadyne Hiker Water Filter Cleaning: stap 3, afbeelding 3 van 3
    • Use the pump handle to remove the filter cap.
    • Place the horizontal groove of the pump handle depicted in image 1 onto the filter fins.
    • Press the pump handle firmly against the fins and turn the filter counter clockwise.
    • Once unscrewed, remove the filter completely from the body.
  4. Katadyne Hiker Water Filter Cleaning: stap 4, afbeelding 1 van 3 Katadyne Hiker Water Filter Cleaning: stap 4, afbeelding 2 van 3 Katadyne Hiker Water Filter Cleaning: stap 4, afbeelding 3 van 3
    • Only perform this step if solid particles are evident on the outside of the filter.
    • Lightly brush the entire filter with a soft bristled toothbrush under running water.
  5. Katadyne Hiker Water Filter Cleaning: stap 5, afbeelding 1 van 1
    • Replace the filter inside the filter body and screw clockwise until tight.
  6. Katadyne Hiker Water Filter Cleaning: stap 6, afbeelding 1 van 1
    • Lubricate the pump handle O-ring extensively with the Katadyne lubricant (sold with pump).
  7. Katadyne Hiker Water Filter Cleaning: stap 7, afbeelding 1 van 1
    • Replace the pump handle inside the pump handle shaft.
  8. Katadyne Hiker Water Filter Cleaning: stap 8, afbeelding 1 van 2 Katadyne Hiker Water Filter Cleaning: stap 8, afbeelding 2 van 2
    • Replace the "snap-fit" guard by pushing directly toward the filter body.
Conclusie
If difficulty pumping persists, a new filter is required.
Één andere persoon heeft deze handleiding voltooid.
Dylan Carey
130 Reputatie
1 Handleiding geschreven
Cal Poly, Team 24-6, Green Winter 2015 Lid van Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Leden
15 handleidingen geschreven
Één opmerking
wow. this is very helpful post.
thanks for nice guide line..
plz cheak out this—https://waterfilterhub.com
Kenny J. Jackson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 693
