Ga door naar hoofdinhoud
Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement
Wat je nodig hebt
  1. Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement, Disconnect the hose: stap 1, afbeelding 1 van 2 Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement, Disconnect the hose: stap 1, afbeelding 2 van 2
    • Make sure the carpet cleaner is turned off and completely disconnected from power.
    • Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
  2. Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement, Remove the bottom cover: stap 2, afbeelding 1 van 1
    • Use a 3 mm hex key to remove two bolts securing the bottom cover.
  3. Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement: stap 3, afbeelding 1 van 3 Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement: stap 3, afbeelding 2 van 3 Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement: stap 3, afbeelding 3 van 3
    • Rotate the bottom cover down toward the bottom of the carpet cleaner, then pull it straight back toward the rear of the carpet cleaner to remove it.
    • Don't completely remove the cover yet. There is a ground wire connecting the cover to the carpet cleaner that must be disconnected first.
  4. Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement, Disconnect the ground wire: stap 4, afbeelding 1 van 1
    • Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
  5. Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement, Remove the check valve hose: stap 5, afbeelding 1 van 2 Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement, Remove the check valve hose: stap 5, afbeelding 2 van 2
    • Use a flathead screwdriver to loosen the hose clamps at each end of the check valve hose.
  6. Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement: stap 6, afbeelding 1 van 1
    • Pull the check valve hose straight off of its hose barb to remove it.
  7. Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement: stap 7, afbeelding 1 van 3 Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement: stap 7, afbeelding 2 van 3 Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement: stap 7, afbeelding 3 van 3
    • Use an angled pick or your fingers to pull the clamp securing the check valve hose nozzle straight out and off of its bracket.
  8. Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement: stap 8, afbeelding 1 van 3 Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement: stap 8, afbeelding 2 van 3 Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement: stap 8, afbeelding 3 van 3
    • Pull the nozzle straight down and out of its bracket.
    • Slide the entire check valve hose up and out of the carpet cleaner.
  9. Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement, Remove the check valve: stap 9, afbeelding 1 van 2 Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement, Remove the check valve: stap 9, afbeelding 2 van 2
    • Pull the shorter hose straight off of the check valve to remove it.
  10. Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement: stap 10, afbeelding 1 van 2 Karcher Carpet Cleaner BRC3015C 2018 Check Valve Replacement: stap 10, afbeelding 2 van 2
    • Pull the check valve straight out of the hose to remove it.
    • Replace the check valve with a 1/4" x 1/4" hose barb.
    • Make sure to slide the hose clamps back onto the hose before reinstalling the hose.
Conclusie
Bijgevoegde documenten
Adam O'Camb
187.699 Reputatie
416 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 859
