Ga door naar hoofdinhoud
Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement
Wat je nodig hebt
  1. Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement, Disconnect the hose: stap 1, afbeelding 1 van 2 Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement, Disconnect the hose: stap 1, afbeelding 2 van 2
    • Make sure the carpet cleaner is turned off and completely disconnected from power.
    • Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
  2. Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement, Remove the bottom cover: stap 2, afbeelding 1 van 1
    • Use a 3 mm hex key to remove two bolts securing the bottom cover.
  3. Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement: stap 3, afbeelding 1 van 3 Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement: stap 3, afbeelding 2 van 3 Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement: stap 3, afbeelding 3 van 3
    • Rotate the bottom cover down toward the bottom of the carpet cleaner, then pull it straight back toward the rear of the carpet cleaner to remove it.
    • Don't completely remove the cover yet. There is a ground wire connecting the cover to the carpet cleaner that must be disconnected first.
  4. Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement, Disconnect the ground wire: stap 4, afbeelding 1 van 1
    • Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
Conclusie
Adam O'Camb
187.210 Reputatie
416 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 425
