Ga door naar hoofdinhoud
Karcher Carpet Cleaner 10066730 2014 Heater Replacement
Wat je nodig hebt
  1. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Lower the device down: stap 1, afbeelding 1 van 3 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Lower the device down: stap 1, afbeelding 2 van 3 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Lower the device down: stap 1, afbeelding 3 van 3
    • Before beginning repairs, disconnect the device from power, disconnect all hoses, drain and depressurize the system, and let the device cool if the heater was recently used.
    • Lower the device down so it is laying on its backside, bottom facing out.
  2. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the wing nuts: stap 2, afbeelding 1 van 1
    • Remove the two wing nuts securing the base to the device.
    • The base is heavy, so be prepared to lower it down slowly once the wing nuts are removed.
  3. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Lower the base down: stap 3, afbeelding 1 van 3 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Lower the base down: stap 3, afbeelding 2 van 3 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Lower the base down: stap 3, afbeelding 3 van 3
    • Lower the base down until the swivel wheels touch the ground.
  4. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Free the hoses: stap 4, afbeelding 1 van 1
    • Use an 11 mm socket to remove the nut and washer securing the hose retainer clamps.
  5. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 5, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 5, afbeelding 2 van 2
    • Use a pair of flush cutters or sharp scissors to cut the zip tie securing the two hoses together.
    • Pull the hose retaining clamps off of the bolt they were secured by.
    • During reassembly, install a new zip tie.
  6. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the output hose: stap 6, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the output hose: stap 6, afbeelding 2 van 2
    • Use a crescent wrench to loosen the 11/16 inch water output hose fitting on the heater.
  7. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 7, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 7, afbeelding 2 van 2
    • Remove the water output hose from its fitting on the heater.
    • Place a shop rag underneath the fitting to catch any drips.
    • Add fresh plumber's tape to the fitting when reinstalling.
  8. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the input hose: stap 8, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the input hose: stap 8, afbeelding 2 van 2
    • Use a crescent wrench to loosen the 9/16 inch water input hose fitting on the heater.
  9. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 9, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 9, afbeelding 2 van 2
    • Remove the water input hose from its fitting on the heater.
  10. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Unmount the heater: stap 10, afbeelding 1 van 1
    • Use a large flathead screwdriver to loosen the pie clamps securing the heater.
  11. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 11, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 11, afbeelding 2 van 2
    • Pull both pie clamps apart, freeing the heater.
  12. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 12, afbeelding 1 van 3 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 12, afbeelding 2 van 3 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 12, afbeelding 3 van 3
    • Roll the heater down and pull it left, away from the device to remove it.
    • Be careful to not snag any hoses when removing the heater.
    • Do not attempt to fully remove the heater yet, as it is still connected to power.
  13. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the wires from the heater: stap 13, afbeelding 1 van 3 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the wires from the heater: stap 13, afbeelding 2 van 3 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the wires from the heater: stap 13, afbeelding 3 van 3
    • Keep track of which wire goes where, marking wires with tape if you need to.
    • Grip the black ground jumper wire by its blue connector and pull directly away from the heater to remove it.
    • Remove the other side of the black ground jumper wire.
  14. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 14, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 14, afbeelding 2 van 2
    • Grip the tan power wire by its blue connector and pull directly away from the heater to remove it.
  15. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 15, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 15, afbeelding 2 van 2
    • Separate the tan and white wires.
  16. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 16, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 16, afbeelding 2 van 2
    • Grip the brown intermittent power wire by its blue connector and pull directly away from the heater to remove it.
  17. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 17, afbeelding 1 van 1
    • Use a 3/8 inch socket to remove the nut securing the ground wires.
  18. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 18, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: stap 18, afbeelding 2 van 2
    • Remove the heater's green ground wire from the stack.
    • The heater's wire should be the upmost wire in the stack after removing the nut.
  19. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the heater: stap 19, afbeelding 1 van 1
    • Remove the heater.
Conclusie
Carsten Frauenheim
100.449 Reputatie
337 handleidingen geschreven
iFixit Lid van iFixit
Community
136 Leden
15.154 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 38
Altijd: 559
