Ga door naar hoofdinhoud
Karcher Carpet Cleaner 10066730 2014 Breaker Replacement
Wat je nodig hebt
  1. Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the screws securing the front panel: stap 1, afbeelding 1 van 1
    • Before beginning repairs, disconnect the device from power, disconnect all hoses, drain and depressurize the system, and let the device cool if the heater was recently used.
    • Use a Phillips screwdriver to remove the six screws securing the front panel.
  2. Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Tilt the front panel down: stap 2, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Tilt the front panel down: stap 2, afbeelding 2 van 2
    • Grip the front panel at the top and tilt down to reveal the switch electronics.
    • The front panel will stay attached to the device with the flexible tubing.
  3. Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the breaker button cover: stap 3, afbeelding 1 van 1
    • Use a 16 mm socket to loosen the nut on the breaker button cover.
  4. Karcher Carpet Cleaner 10066730 2014 Breaker Replacement: stap 4, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Breaker Replacement: stap 4, afbeelding 2 van 2
    • Remove the breaker button cover.
  5. Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the breaker wires: stap 5, afbeelding 1 van 2 Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the breaker wires: stap 5, afbeelding 2 van 2
    • Separate the breaker from the front panel.
  6. Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the breaker: stap 6, afbeelding 1 van 3 Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the breaker: stap 6, afbeelding 2 van 3 Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the breaker: stap 6, afbeelding 3 van 3
    • Grip the black wire by its blue connector and pull directly away from the breaker to remove it.
    • Grip the dark blue wire by its blue connector and pull directly away from the breaker to remove it.
    • Make a note of which wire goes where to help during reassembly.
    • Only the breaker remains.
Conclusie
Carsten Frauenheim
100.722 Reputatie
337 handleidingen geschreven
iFixit Lid van iFixit
Community
136 Leden
15.176 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 269
