Ga door naar hoofdinhoud
Kangen Leveluk 8 Filter Replacement
Wat je nodig hebt
  1. Kangen Leveluk 8 Filter Replacement, Do a Filter Check: stap 1, afbeelding 1 van 3 Kangen Leveluk 8 Filter Replacement, Do a Filter Check: stap 1, afbeelding 2 van 3 Kangen Leveluk 8 Filter Replacement, Do a Filter Check: stap 1, afbeelding 3 van 3
    • If you are unsure of the issue with the machine, do a filter check.
    • Turn on the machine and select "Setting" at the bottom of the menu.
    • Select "Filter Check" located towards the bottom of the Settings list; it is the second-to-last option.
    • If the filter check menu indicates that the filter needs to be replaced, proceed with following steps.
  2. Kangen Leveluk 8 Filter Replacement, Turn off Sink and Water Supply: stap 2, afbeelding 1 van 3 Kangen Leveluk 8 Filter Replacement, Turn off Sink and Water Supply: stap 2, afbeelding 2 van 3 Kangen Leveluk 8 Filter Replacement, Turn off Sink and Water Supply: stap 2, afbeelding 3 van 3
    • Shut off the water supply to the machine.
    • Ensure your sink is not running or the filter compartment will leak water during the process.
    • The location of the water supply to the machine depends on your sink.
    • For an extra precaution power off the machine and unplug it.
    • If the water is on during installation, the filter will leak water.
  3. Kangen Leveluk 8 Filter Replacement, Remove the Lid: stap 3, afbeelding 1 van 3 Kangen Leveluk 8 Filter Replacement, Remove the Lid: stap 3, afbeelding 2 van 3 Kangen Leveluk 8 Filter Replacement, Remove the Lid: stap 3, afbeelding 3 van 3
    • Push the white arrow up on the left side of the machine to remove the filter compartment cover.
  4. Kangen Leveluk 8 Filter Replacement, Unlock Filter from Compartment: stap 4, afbeelding 1 van 3 Kangen Leveluk 8 Filter Replacement, Unlock Filter from Compartment: stap 4, afbeelding 2 van 3 Kangen Leveluk 8 Filter Replacement, Unlock Filter from Compartment: stap 4, afbeelding 3 van 3
    • Gently push the locking mechanism in a clockwise direction until it comes out of the slot.
    • When the filter is removed the lock will completely come out of the slot. This means the lock will have to be reinserted after installation.
  5. Kangen Leveluk 8 Filter Replacement, Remove the Filter: stap 5, afbeelding 1 van 3 Kangen Leveluk 8 Filter Replacement, Remove the Filter: stap 5, afbeelding 2 van 3 Kangen Leveluk 8 Filter Replacement, Remove the Filter: stap 5, afbeelding 3 van 3
    • Remove the existing filter from the filter compartment.
    • Place a cloth underneath the filter compartment to catch any water that may leak during removal.
    • Align the new filter with the threads inside the filter compartment. Adjust as necessary.
    • If the machine is plugged in during the installation, it will notify you if the filter is installed in the compartment.
  6. Kangen Leveluk 8 Filter Replacement, Insert the Filter Lock: stap 6, afbeelding 1 van 3 Kangen Leveluk 8 Filter Replacement, Insert the Filter Lock: stap 6, afbeelding 2 van 3 Kangen Leveluk 8 Filter Replacement, Insert the Filter Lock: stap 6, afbeelding 3 van 3
    • Insert the locking mechanism into the machine by pushing it into the slot on the right side of the filter compartment.
    • Push the lock in a counter-clockwise direction until reaches the end of the slot.
    • Ensure that the filter is installed before reinserting the filter lock or the filter will not fit in the compartment.
  7. Kangen Leveluk 8 Filter Replacement, Check for Filter Errors: stap 7, afbeelding 1 van 1
    • Turn on the machine and check for any error messages.
    • If there are errors and you machine is powered on, the filter error screen will appear immediately after installation.
    • If the machine notifies you of any filter errors after installation, the filter has not been installed correctly or it is not compatible with the machine.
  8. Kangen Leveluk 8 Filter Replacement, Close Filter Compartment, Test Run Machine and Dispose Old Filter: stap 8, afbeelding 1 van 1
    • Close the filter compartment.
    • Test run the machine with water to ensure it runs properly with the new filter and to see if there are any more errors.
    • Inspect the filter compartment for any leaks.
    • If you notice any leaks when running the machine, immediately turn off the machine, unplug it, and double check filter installation.
    • The old filter can be disposed of in a garbage bin.
Eindstreep
caem366
157 Reputatie
1 Handleiding geschreven
York University, Team C-44, O'Regan Fall 2023 Lid van York University, Team C-44, O'Regan Fall 2023
YORK-O'REGAN-F23SCG44
2 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 87
Altijd: 382
