Ga door naar hoofdinhoud
KLH Speaker Driver Replacement
Wat je nodig hebt
  1. KLH Speaker Driver Replacement, Driver: stap 1, afbeelding 1 van 1
    • This is what the speaker will look like when you start.
    • Step 1: Remove the speaker cover.
  2. KLH Speaker Driver Replacement: stap 2, afbeelding 1 van 1
    • Step 2: Remove all 4 of the 2 cm screws.
  3. KLH Speaker Driver Replacement: stap 3, afbeelding 1 van 1
    • Step 3: Carefully remove the speaker from the speaker box. Be sure not to break the 2 wires connecting the speaker.
  4. KLH Speaker Driver Replacement: stap 4, afbeelding 1 van 1
    • Step 4: Carefully cut the 2 wires connecting the speaker. Make sure to cut the wires about half way from the speaker.
  5. KLH Speaker Driver Replacement: stap 5, afbeelding 1 van 1
    • Step 5: Make sure the the new speaker is the same size, and is ready to be placed inside the cabinet.
  6. KLH Speaker Driver Replacement: stap 6, afbeelding 1 van 1
    • Step 6: Strip both of the wires so they are ready to be soldered together.
  7. KLH Speaker Driver Replacement: stap 7, afbeelding 1 van 1
    • Step 7: Solder the wires together.
  8. KLH Speaker Driver Replacement: stap 8, afbeelding 1 van 1
    • Step 8: Screw the new speaker back into the box using all 4 of the 2 cm screws.
  9. KLH Speaker Driver Replacement: stap 9, afbeelding 1 van 1
    • Step 9: Place the cover back onto the speaker box.
Conclusie
Één opmerking
Be sure to note that the new speaker will have a burn in timed may not sound as good as the old till it gets played for awhile. It is important that the new speaker matches the old as the crossover may not work with a different speaker that does not match the original.
ronjon76 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 1,590
