Ga door naar hoofdinhoud
K-Gro PowerPro Lawnmower Drive Cable Replacement Guide
Wat je nodig hebt
  1. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide, Drive Engagement Cable: stap 1, afbeelding 1 van 2 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide, Drive Engagement Cable: stap 1, afbeelding 2 van 2
    • Locate the throttle assembly on your mower on the right side of the push bar.
  2. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 2, afbeelding 1 van 3 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 2, afbeelding 2 van 3 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 2, afbeelding 3 van 3
    • The throttle assembly is attached to the push bar with a 7/16" bolt and nut.
    • Using a 3/8" drive rachet wrench with a 7/16" socket and a 7/16" combination wrench, remove the nut.
    • Pull the plastic cable connection away from the framework.
  3. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 3, afbeelding 1 van 2 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 3, afbeelding 2 van 2
    • After disconnecting the plastic connector plate from the main body, you can see that the cable is hooked and looped around the orange handle.
    • Pull the cable towards the handle to allow the wire to become loose. This will give you enough room to remove the hook.
  4. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 4, afbeelding 1 van 3 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 4, afbeelding 2 van 3 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 4, afbeelding 3 van 3
    • Following the cable down to the engine, you see that a zip tie holds the cable to the main handle.
    • Use a box cutter, sharp pocket knife, or cutting pliers to cut the zip tie.
    • Use gloves to prevent cutting yourself.
  5. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 5, afbeelding 1 van 2 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 5, afbeelding 2 van 2
    • Locate the plastic fitting hooked to the steel housing of the engine.
    • To the left of the fitting, you will see a steel sliding mechanism connected by a spring.
    • Squeeze the mechanism together to allow for slack in the cable wire.
    • You might need to use pliers or clamps in order to squeeze the plates together.
  6. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 6, afbeelding 1 van 3 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 6, afbeelding 2 van 3 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 6, afbeelding 3 van 3
    • On close inspection of the plastic fitting, you can see that there are two "wings" that can be pinched together.
    • With the sliding mechanism squeezed and the wire slack, pinch the plastic wings together and push the fitting to the right out of the hole in the housing.
    • The loose wire can then be slid up through the groove in the steel.
  7. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 7, afbeelding 1 van 2 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: stap 7, afbeelding 2 van 2
    • You can see that the only thing still holding the cable on is a hook attached to a spring loaded lever.
    • Remove the hook.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Julio Acosta
125 Reputatie
1 Handleiding geschreven
Texas Tech, Team 3-6, Rauch SU 2016 Lid van Texas Tech, Team 3-6, Rauch SU 2016
TTU-RAUCH-SU16S3G6
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 1,731
