Inleiding
Jura Z models have two outlet valves. These valves must be checked more often. The valve plunger often breaks off and the plunger then gets stuck. The seals age over time. A remedy is a new plunger, preferably made of metal.
Wat je nodig hebt
Remove all attachments: water tank, drip tray, aroma lid
Behind the Jura sign are two screws with an oval head. They have to be removed.
These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit for their removal. If the right bit is not available, it could be done with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!!
This step shows how to remove the top cover
Remove the powder tray and all coffee beans.
The cover is fastened with three Torx T15 screws. Those are easily visible under the covers as well as the small cover on the left back side.
Remove the two Phillips screws on the bean container and remove the bean container.
Lift the cover upwards.
Pull out the clamp on the lower outlet valve.
Carefully slide the lower outlet valve to the left so that the pressure hose comes out. Watch out for the O-ring. It will either get stuck in the valve or on the end of the hose. Replace it with a new one when reassembling.
Lift out the valve. The two hoses on the left can stay on.
The cover on top of the valve is held by three detents. Gently release the three detents with the flat end of a spatula and lift the cover straight up.
Carefully lift out the spring and valve stem. Pay attention to the sequence for later reassembly.
Work through the steps in reverse order to reassemble your device.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
