Inleiding
The magnetic valve at the top rear can either be malfunctioning - in which case the water/steam draw will no longer work properly - or the valve body can be leaking. Replacing the magnetic valve is easy.
Note: This instruction also involves removing the top and side covers. However, this is only necessary if you want to do further repairs. You can just remove just the back cover if you are not doing any other repairs.
Wat je nodig hebt
Lift out the coffee tray
Remove the lid sealing the coffee bean container
Remove all of the coffee beans you can possibly remove.
Pull the adjuster of the coffee bean grinder straight up
Remove the four T15 Torx screws
The backpanel is secured with two proprietary screws with oval head. They seem to be rivets, but in fact are screws. The only purpose is, to keep us out of our own devices. You can remove them using an oval drive bit. (Part of some IFixit tool collections or available at a Jura provider or iFixit). In a pitch try needle nose pliers. Here a DIY guide.
Remove the two oval head screws on the lower edge of the backpanel.
Lift the panel up.
Remove the knob for the steam valve by simply pulling it off.
The front cover is secured with a Torx T15 screw. Remove it.
The white support of the valve is fixed in two slotted holes in the slanted part of the metal cage. The carrier must be shifted upwards by about 1 cm, then the valve can be lifted out.
The carrier is held in place by two small plastic catches. Press the plastic catches in from below with an angled pointed tool, then the catches are free.
Lift the valve out upwards.
The valve is still connected to three cables. Pull off the cable lugs, note the position.
The valve is connected with hoses at the front and rear. Pull out the clamps and disconnect the hoses. An O-ring is attached to the hose for sealing. It gets stuck on the hose or in the valve. Replace it with a new one when reassembling.
Work through the steps in reverse order to reassemble your device.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
shingle helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
