Inleiding
Prerequisite only - This guide is only part of other guides.
Removing the grindstones in grinders of the OEM manufacturer Eugster. (Jura and similar ones e.g. AEG and Siemens, Bosch, Melitta, Nivona, Krups)
Wat je nodig hebt
Now the grinder is free. Again take a picture, then pull out the axis of the adjuster with moderate force.
Depending on the model you will find a silicon sealing on top of the grinder ring, remove it.
Watch the fabrication signs , here green. This alignment must be restored later. Now turn the great black gear about 90 degrees counterclockwise. The grinder ring is free and can be lifted off.
The grinding cone is fastened with a long Torx T20 screw. The screw head is often covered with remnants of coffee beans. Expose the head and turn the screw out counterclockwise.
Now the bean feeder (the small white snail) can be removed. The grinder cone and drive can now also be lifted up carefully.
The grinder is usually filled with old, sticky coffee grounds. Clean everything carefully for an excellent coffee aroma.
Gently lift the felt ring around the drive shaft with a needle, then wipe it clean with a damp cloth. Do not attempt to wash it, as there is a risk that it will swell. When first used, turn it over with the clean side up.
Clean the inside of the grinder with a brush and damp cloth, and the blades with a dishwashing brush. Ensure it is properly dried before use.
What is your process for cleaning the felt ring once removed from the drive access?
I use a damp rag with a little dishwashing liquid. Another option is to simply turn the ring upside down.
VauWeh -
Cleaning the felt ring ruined it.
Do you know any vendor in the US that sells the felt washer?
Jan Don -
As I´m german, sorry no. Perhaps they do: https://www.jura-parts.com . And have a look for Capressa Infinity grinders, it´s the same. Or make one DIY using a piece of felt.
VauWeh -
the water expanded the felt ring and it did not shrink back once dry.
Can you recommend a parts place in the US to get this felt washer? The link you sent does not show that it would fit the
Jura ENA4.
-Roger
In this case things are different. Did you really replace the grindstones? Or only clean the device? When my informations are right the ENA 4 is equipped with a "Aroma +" grinder, which means special grindstones, not the normal ones. As far as I know Jura does not sell them separately, only the complete grinder. I think, the felt ring will fit, but I don't know where to buy in the US. I think, the grinder also will work without the ring or cut one of a piece of felt. Good luck!
VauWeh -
If you can't find the felt ring, you have a few options, make one, beg the German jura parts seller to sell you one, or search aliexpress for felt ring, felt washer, felt gasket.
Hello. The piece where the springs and ball bearings are housed: where can I buy a replacement, please if you know.
Thanks
Same thing happened with my felt ring. It expanded and never retracted after washing. Did anyone figure out where to buy it in the US?
The Capresso Infinity grinder should be the same, so look for someone who supplies its parts.
VauWeh -
Make one, lots of materials at your local hobby store or online. https://www.aliexpress.us/item/325680549...
If you can't find it a wool washer from Michael's or Joann etc will work. You can also get them online at aliexpress and ebay.
Push both of the small latches alternately. Then the ring cover should come out.
Two clamps hold the grinder ring in its place, push them aside and it should come free.
Again clean everything. Press the new ring and cover in its place. With that the grinder ring is exchanged.
First insert the cleaned driver, then the three sleeves, springs and balls. Now fit the grinding cone on the three balls.
Then fit the auger, screw in central screws. When screwing in, push the cone downwards and make sure that everything meshes.
Everything is in right place
I push as hard as I can. But it seem the that the screw is turning in the void. I remove all the part to see if the hole was strip , the screw seem to enter firmly
In this case I fear, you have to buy a new grinder. Replacing it is straightforward.
VauWeh -
i find a bit longer screw and it work but now the black ring is spinning in the void. the black outer ring and the white outer ring are suppose to be turning together ?
I have one more spring and ball, that are half a diametr of the rest. Can’t figure out where do they go?
Might be the ball and spring beyond the big black gear, makes the “click", when turning it.
VauWeh -
Thanks. I followed the steps on the Nivona grinder and replaced the springs and the balls in the exact order. Now the grinder can only grind finely and this is too find for my brewer and hence my espresso machine is clogged. Can anyone see what when wrong after the reassembly?
I think the parts don't fit together properly. First: There are three holes on the bottom of the cone that the balls must fit into. Second: at the bottom of the helix are two tabs that must fit into corresponding grooves.
VauWeh -
How tight should you screw this screw in? Until it can no longer turn the screw driver?
Short answer: yes, not to hard. The screw ist spring loaded and cannot move easily. Be sure that the helix fits.
VauWeh -
hello, changed the burrs and the coffee was too fine, clogging the machine. Haven't read correctly your tuto !!
The adjustment oft the new grinder burrs must not necessarily be the same as the old ones. You can approximately find the mean position, which was marked before, by turning the outer ring as far as possible clockwise, then turning it fourteen clicks backwards.
So you should not reallign the green mark , but use the 14 clicks from the grinder full closed for medium.
En remontant les meules, on serre jusqu’à toucher les 2 cônes en tournant dans le sens des aiguilles, puis 14 clics dans le sens inverse pour avoir le réglage medium. Surtout si on a serré la vis centrale différemment du montage initial.
Insert grinding ring. The black gear is turned to the right again until the three marks are aligned. Then reinstall the adjuster drive shaft as it was originally.
Then install the remaining parts in reverse order.
You can set the grinding degree nicely by placing an empty roll of toilet paper perpendicular to the open mill and filling it with a few coffee beans. Plug in the plug (be careful!), choose a cup of coffee and watch as the coffee grounds fall out of the grinder.
i turn the black gear but the white one doesnt turn any more , they are suppose to turn together?
By turning the the black gear the grinder ring moves a little bit up and down and changes the grinder setting. The white ring holding the grinder ring indeed does not move. Or do you mean the big white gear beyond the black one? If the black and the white gears are not connected, press firmly the black gear down, until it clicks in.
VauWeh -
i remove a part the black and the white ring, it seem that there was black pin on the black ring that was maybe glue to the white ring ? but it seem broken or unglue , it whitish on the tip like if it was broke
unless i see nothing that make those 2 ring jam together. maybe i should try to reglue with a dot of epoxy ?
Thanks ! Alot!
Super Anleitung. Die neue Mahlsteinen war deutlich anders als die alten. Ich habe die Einstellring so weit wie möglich nach rechst gedreht, dann 14 Zähnen nach links, wie beschrieben. Die Maschine malt jetzt perfect. Danke.
if you move the ring fourteen clicks back, it means maximum opening or closing of the setting. Hope you understand what I mean. With these fourteen clicks, how to set this adjustment stick
First turn the ring clockwise so that the grindstones sit tightly on each other. Then open it by turning the ring counterclockwise for fourteen clicks. This is a medium setting. You can do a fine adjusting later. Watch the grinder in action using the toilet-paper-roll method. Good luck!
VauWeh -
Ok. Thank you very much.
I am looking to do the same replacement. The instructions looks great but I cannot find anywhere where to buy the two pieces grinder compatible for a ena micro 1. Any suggestions where I could buy that?
This is indeed difficult. The grinder of the ENA Micro 1 is special. So far I have unfortunately only found the complete grinder, very expensive. (~ 150€). A reason not to buy this model, but that's no use to you anymore.
VauWeh -
or a cheaper used one (~70€): https://www.jura-ersatzteile-shop.de/mah...
VauWeh -
you can get that on eBay and aliexpress/alibaba. if you like take out the burrs and and measure them and I can tell you if they are the common ones being sold everywhere.
If you mark and line up all the rings as well as the spot on the “coarse -fine” adjuster and return them to the exact position at the end, do you have to bother about turning the clicks counterclockwise at the end.
Well, try it. Normally, everything should work fine and you can check the result on the grind. But the method with the 14 clicks is really simple.
VauWeh -
Great video. Ma problem is, there were only one mark on the rings, and I didn't mark the rings. Will the 14 clicks be enough initial adjustmet? Why is part of the black ring raised, and where does it go in relationship to the coffee shute? Thanks for any help
Did you remove the black ring? If the (green?) mark on the outer white ring is on 12, the middle of the raised part is on 8, as far as I remember. It serves as stop, there is a counterpart in the bean reservoir. Not really important and not in every model. And yes, the 14 clicks work fine. Try the grinder open, putting an empty toilet paper filled with some beans on it.
VauWeh -
Thanks for the instructions. It all worked out, but for me it was easier to remove the whole grinder housing (3 screws) in order to remove the top part (step 7).
Also, before removing the grinder cone and the 3 springs and the 3 balls, a smaller spring and a smaller ball fell off somewhere and I could not figure out where to put them. Again all 3 springs and balls are as you describe but the extra smaller one I left out while re-assembling.
At the end it is a success, but was curious if you knew where these extra parts are from
Sounds like the that's what makes the clicking sound when you adjust the grinder from course to fine.
If you remove the top, black ring with the gear teeth, you will expose the off white plastic, it has holes all the way around,
that where the ball and spring go to make that clicking sound. Not a big deal, I misplaced mine and I've been using the grinder
for a few years now without it. https://www.juraprofi.de/Jura-Ersatzteil...
@jimmylasvegas is right. This ball is the detent for the adjustment of the grinder.
VauWeh -
I cleaned the grinder because it was dirty and didn't grind well: no coffee output. After everything is cleaned and replaced it is turning free but doesn't grind. There is still no coffee output. I do not understand why the coffea beans do not come through the grinder. Has anybody a soluton?
Thank you! I want to attempt this service after reading your post.
Do the grinding burrs fit an XJ9 Jura? I cannot find the parts at a reasonable price anywhere else. Any advice is very much appreciated
You need special grinder burrs, as it is a Aroma+ grinder. In the meantime they are available. I do not know, If they will ship it to your country, at least in europe they do.
VauWeh -
These two pictures are no fake: Before repairing the grinder the coffee is thin and transparent. With new stones the coffee is strong and has a fine crema. The repair was a real success!
This is very helpful. My question is that when disassembling the unit, a very small ball came loose (not one of the balls under the grinder cone that you flagged). Now my grinder does not adjust for a fine grind so i think the ball was somewhere in the grinder adjustment assembly?
Thanks
Yes. This must be the ball in the grinder adjustment. Have a look to the steps 5 - 7 in the guide for saeco: https://de.ifixit.com/Anleitung/Saeco+Vi..., the grinder is nearly the same. The big black gearwheel can be lifted upwards using a little force and you can see all those little holes - and the ball was sitting under one of them thus keeping the adjuster in position. Hope it helps and you can fix it!
Do you have a picture of where that tiny spring and ball should be placed back? When I was unscrewing the grinder unit from the body (hadn’t yet disassembled the grinder itself) the little spring and ball hopped out of somewhere and my video didn’t catch where from. I have a Bosch Benvenuto built-in and couldn’t find it in the parts diagram catalog.
Jan Don -
Yes Sir, e.g. here, picture included.
VauWeh -
You lost your balls? there’s 2 ball bearings that make the clicking sound as you adjust the grind. I lost both of mine, never found them again. Anyone know what size they are? you can buy new balls at a local bearing store or on alibaba/ebay.
Hello VauWeh,
I’ve cleaned my grinder and assembled it back. One thing I can’t restore is that grinder adjuster doesn’t click anymore. Could you please advise something that might affect it? The coffee is perfect but the grinder setting doesn’t stay in place. When it grinds, vibration makes it move towards a more coarse setting.
Hello, as I mentioned in my answer dated 18.11.2019, I suppose you lost the ball, which makes the clicking sound and holds the position of the big wheel. Sorry, I don't know a solution for that.
VauWeh -
Thanks, coffee is black now, and full of aromas but a bit strong !! So take some time before reassembling all , to set the outer ring for default medium grind, not respecting the outside green mark.
Merci le café est maintenant noir et sent très bon. Le réglage de la bague doit se faire avant de tout remonter, pour régler la finesse de monture par défaut. J'allais jeter la machine....
Thank you very much for the clear instructions. I started with just disassembling the grinding unit of my 9 years old Solo and cleaning it. That did not give the results I was hoping for. Bought an new set of grinders, installed following these instructions and the result is fantastic. Hoping for another 9 years on this machine with the help of the repair guides on this site (of which I have successfully used a couple now).
It is always a pleasure for me when my guide could help.
VauWeh -
ou trouver les meules pour une caffeo solo ?
Ce sont les mêmes que pour Jura, affichées dans l'introduction.
VauWeh -
Now follow the remaining steps in reverse direction to reassemble your device.
11 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
22 opmerkingen
Thank you for the guide. I have FILL BEANS error, I followed this guide. No problem. But with new burrs, I still have FILL BEANS error. Any idea why? My burrs were not so bad. I only have 2000 espressos on the counter.
Which model of Jura is it?
VauWeh -
Z5, first generation
The fame “fill beans” error is that not enough coffee is entering the brewgroup. I have cleaned the grinder and the chute to the brewgroup. Grinder spins fast. But very little coffee actually go down into the grinder. I have watched several youtube videos on grinder calibration. But no idea. If you use the 2 big espresso cup button, then no error because the grinder runs a longer time. But still not enough coffee for 2 large cups. Just no error.
Thanks for helping!
I have check the feeding helix.
I will try the toilet paper tube and see what happens. I have to buy more beans.
This morning I replaced the grindstones in a J5 and - had the same issue. Fill beans error. Using the toilet paper tube I could see the grinder spinning, but nearly no coffee grounds falling into the brewing unit. So I took off the helix and inserted it again. I'm sure, it was misaligned. There ist a groove in the drive shaft and two taps in the lower end of the helix have to fit in! If this ist not the case, the distance between both grindstones is not correct.
Are you getting any errors? like fill beans? Have you tried turning up the settings to make a stronger espresso? Also fill the bean hopper to the top and test.
Excellent instructions. Unfortunately, I took things apart first and lost the bearing sleeve before reading steps 5-7. Do you know where I can get a replacement?
It’s not a big deal if you can’t find it. Just use some thin tubing, plastic, metal, copper, etc. Check aliexpress and your local hardware store.
There are three. Did you really lose all of them? Some grinders are not equipped with bearings.
VauWeh -
Hi - need some FINE TUNING advice on my ENA3. When replacing burr assembly and turning white ring CCW until the triangle mark aligns w the other 2 markings. Then reinstalling top burr assembly and rotating white collar CW as far as possible, how many clicks should it then be turned CCW? I’ve read anywhere from 6-14? If too tight, coffee won’t produce hardly any coffee and seems to get constipated! Thank you!!
...See this guide. (Use Google translate). Make sure you've got the right burrs, there are two types.
VauWeh -
