Ga door naar hoofdinhoud
Jura Capresso IMPRESSA J5 Drainage Valve disassembly
  1. Jura Capresso IMPRESSA J5 Drainage Valve disassembly, Jura Capresso IMPRESSA J5 Drainage Valve disassembly: stap 1, afbeelding 1 van 3 Jura Capresso IMPRESSA J5 Drainage Valve disassembly, Jura Capresso IMPRESSA J5 Drainage Valve disassembly: stap 1, afbeelding 2 van 3 Jura Capresso IMPRESSA J5 Drainage Valve disassembly, Jura Capresso IMPRESSA J5 Drainage Valve disassembly: stap 1, afbeelding 3 van 3
    • When lots of water leaks under a Jura brew-group it could be a broken sealring at the drainage. The first sealring is shown inside the white circle. This sealring has a lot of mechanical stress because at this point the brew-group moves up and down. From here comes the fresh water. The screwdrivers points at the metal spring-claw to pull off.
    • For this guide i have chosen a cleaned drainage valve. In real maintenance it will be extremly filthy, greasey and lots of coffee crumbs will trickle down. Use papertowel, toothpick,. toothbrush and degreasespray and clean everything under water.
    • Turn the valve and use the screwdriver to leverage the white part with the spring. It should come up; if nothing moves it needs better cleaning because the grease here is very sticky.
    • Now all the parts should fall off the valve block. Hold your hand above it because the spring could snap away.
  2. Jura Capresso IMPRESSA J5 Drainage Valve disassembly: stap 2, afbeelding 1 van 2 Jura Capresso IMPRESSA J5 Drainage Valve disassembly: stap 2, afbeelding 2 van 2
    • Here you can clearly see how that docking-part works. That seal has big mechanical stress because here the piston docks on.
  3. Jura Capresso IMPRESSA J5 Drainage Valve disassembly: stap 3, afbeelding 1 van 1
    • The parts of the valve. You can see the two bigger rings: they are located INSIDE the big T-tube.
    • The FLAT side of the big sealrings point to OUTSIDE left and right. All plastic-parts have notches, look for them when reassembling these parts.
    • The white fresh water hose has a metal spring-claw, too and can also pulled away if consisted.
    • When reassembling use a little bit of food-silicone-grease on every sealring.
  4. Jura Capresso IMPRESSA J5 Drainage Valve disassembly: stap 4, afbeelding 1 van 3 Jura Capresso IMPRESSA J5 Drainage Valve disassembly: stap 4, afbeelding 2 van 3 Jura Capresso IMPRESSA J5 Drainage Valve disassembly: stap 4, afbeelding 3 van 3
    • Clean and grease all selrings with food-silicone-grease.
    • When reassembling start with the part as shown on the first photo. Don't forget the sealring on both ends !
    • Second and third picture show the ready assembled valve: Push the white part with the spring together and insert it in the valve-block. You see the notches, they only fit in one direction. :) I now understand that my camera is bad, I hope I may buy a better one.
  5. Jura Capresso IMPRESSA J5 Drainage Valve disassembly: stap 5, afbeelding 1 van 3 Jura Capresso IMPRESSA J5 Drainage Valve disassembly: stap 5, afbeelding 2 van 3 Jura Capresso IMPRESSA J5 Drainage Valve disassembly: stap 5, afbeelding 3 van 3
    • The first picture shows the drainage-valve-block from the right side. The white, round part must sit in center of the circle, otherwise it won't close and water will run through it.
    • Push it sometimes it should move easy.
    • Don't forget the spring-claw to secute the tube from the valve.
    • That's it, now you can replace the drainage valve back in the brew-group of your nice Jura. :)
    • You can find another Jura Drainage Valve Teardown, there are many better pictures to help you better. :)
Conclusie
6 andere personen hebben deze handleiding voltooid.
Schwarzstein
2.813 Reputatie
13 handleidingen geschreven
6 opmerkingen
When brewing unit assembled, whre is a gap 1 mm between tube of drain valve and docking hole of piston, so water pass down. How to fix it?
Andrii - Antwoord
Maybe my answer is a little bit to late. I cannot imagine that there is a gap. I suppose you lost the gasket. This ring normally can easily be bought at a jura supplier. Dont forget to apply a little bit of food-proof silicone lubricant.
VauWeh - Antwoord
On the Jura Impressa Z9 the drain valve has a back cover that is fixed. Can it be removed to overhaul the valve, and if so how is it put back to gether?
Darryl - Antwoord
I'm sure there is a method to remove it. Perhaps this helps. Did you already open the brewing unit?
VauWeh -
Jura ENA 5 Drain valve is similar but I have a problem where water and steam leaks from the nipple after the rinse has been completed. It seems like there is pressure build up and the valve cannot hold. I have 2x ENA 5 machines. I have tried 2 different drain valve assemblies and both leak on one faulty machine. Could this be related to the PCB? If I don’t turn off the power quickly when the steam leak starts, the overheat fuse will break on the water block and cause Error 1.
It seems the water heater block can not control the heat and causes the drain valve to leak steam. I have error 1 (from water block overheat). I replaced the fuse and again steam comes out the drain valve. How to test the PCB to confirm?
Stu - Antwoord
See Jura ENA micro 9 Drainageventil revidieren (in german) , the long pin with the plastic cap in the drainage valve is opened by a motor. Maybe it's broken?
(Picture)
VauWeh -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 99
Altijd: 18,003
