Inleiding
There are different techniques to replace an Intel Celeron Jumper Laptop Touchpad. To complete this guide, you will absolutely need two screwdrivers which are (1) a screwdriver and (2) a flat-blade screwdriver. To replace a touchpad, you will also need a new touchpad.
Reminder: Your new touchpad should be the correct size corresponding to the size of your laptop.
Wat je nodig hebt
Place the laptop so the bottom is facing upwards.
Remove the two 8 mm screws on the back of the laptop using a T3 Torx screwdriver.
Remove the three 5 mm screws on the back of the laptop using a T3 Torx screwdriver.
Remove the six 4 mm screws on the back of the laptop using a T3 Torx screwdriver.
Remove the single 3 mm base screw inside the battery case using a T3 Torx screwdriver.
