Ga door naar hoofdinhoud
Deze vertaling is door een computer gegenereerd en is nog niet door iemand nagekeken. Spreek je deze taal? Bekijk het hier.
Joy-Con links-synchronisatieproblemen oplossen
Wat je nodig hebt
Video-instructies
Conclusie
Volg deze instructies in omgekeerde volgorde om je apparaat weer in elkaar te zetten.
12 andere personen hebben deze handleiding voltooid.
Taylor Dixon
72.878 Reputatie
94 handleidingen geschreven
7Gids Commentaar
What thickness of conductive foam should I choose? There are 3 sizes: 3mm/0.12, 5mm/0.20", 10mm/0.39"
maximaleks - Antwoord Deel
The space is ~9 mm wide, so I would go with the 10 mm size and you can trim it down if you need to!
Taylor Dixon - Antwoord Deel
I've got the same problem but with the right joycon but I don't know where the wireless card is, please help
Nathan Currie - Antwoord Deel
Hello I opened up my left joycon and saw conductive foam inside already! I replaced it with one that I bought on amazon (I made sure it was actually conductive foam). But it still won’t sync. Any ideas? Could it be that little solder bubble that connects to the antenna has gone bad? Should I try to reflow it? I also checked to see if any capacitors in the top of the board were shorted and none of them were. If you have any ideas I would be happy to hear!
Chaim Bendahan - Antwoord Deel
I opened my left Joycon and found that there is no antenna area near the joystick compartment. It’s just an empty space what should I do, I have the conductive foam but obviously don’t know where to place.
Omar Gonzalez - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 473
Afgelopen 30 dagen: 1,024
Altijd: 53,184
