Ga door naar hoofdinhoud
Joy-Con Motherboard Replacement
Wat je nodig hebt
  1. Joy-Con Motherboard Replacement, Find Y00 screws: stap 1, afbeelding 1 van 1
    • I'm going to use left Joy-Con, but it doesn't matter which Joy-Con
  2. Joy-Con Motherboard Replacement, Unscrewing: stap 2, afbeelding 1 van 1
    • Take your Y00 screwdriver and get to work! Unscrew the screws
  3. Joy-Con Motherboard Replacement, Opening: stap 3, afbeelding 1 van 1
    • Carefully open the Joy-Con backshell, take your time!
    • Note: It has wires attached, BE CAREFUL!
  4. Joy-Con Motherboard Replacement, Unscrewing backshell: stap 4, afbeelding 1 van 1
    • Backshell can get really annoying, so why won't we just unscrew it? Take 00 screwdriver and let's get it done!
    • Note: DO NOT unscrew bolts on an LED strip.
Conclusie
Savalio AnanaNIMus
37 Reputatie
1 Handleiding geschreven
Één opmerking
This guide only stops at removing the outer screws and doesn't show the fill process. Please update.
Shannon W - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 71
Afgelopen 30 dagen: 303
Altijd: 632
