Inleiding
Change your tractor's engine oil and filter every 100 hours of use to keep your crops coming season after season.
Wat je nodig hebt
Pull the hood release latch at the front right of the tractor and lift the hood up.
The drain plug is a 17 mm hex bolt located on the underside of the tractor.
Use a 17 mm box end wrench to loosen the drain plug 3/4 of a turn.
Move the oil drain pan so that it is directly under the oil filter.
Remove the oil filter by turning it counterclockwise until it comes free.
Place the oil filter with the open end facing down onto the oil drain pan to allow the old oil to drain out.
Dip a clean, gloved finger into a fresh bottle of oil and spread a thin layer of oil on the new oil filter's gasket.
Wipe off the oil filter threads and contact area on the engine with a clean rag or towel.
Place the new oil filter over the threads and turn it clockwise until it is snug.
Twist the oil filler cap counterclockwise and remove it from the valve cover.
The engine oil dipstick is located on the right side of the engine and has a yellow handle.
Remove the dipstick, wipe it off with a clean rag or towel, reinsert it, and remove it again.
Read the initial oil level. It should be somewhere in the crosshatched region. It is acceptable for the level to be slightly high, since it hasn't filled the oil filter and other nooks and crannies of the engine yet.
Reinsert the dipstick and add or remove any oil, if necessary.
Allow 12-24 hours for all of the oil to drain out of the old oil filter.
Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge to you. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
If you're lucky, maybe she'll think your tractor is sexy.
9 andere personen hebben deze handleiding voltooid.
5 opmerkingen
David Hodson. I felt I owe acknowledge your generosity. I now own this professional tool that is greatly valuable for a commom latin american guy. G. bless your generations forever. Thank you so much.
Clear, concise accurate and exacting pictures with the perfect amount of directions. Fantastic job and best tutorial available for the John Deere 870
The octane no. is a rating for the antiknocking property of petrol.In the test engine, 100 octane petrol has the same antiknocking as isoheptane and 0 octane same as n-octane.
I kept my voice low, "I think your !&^&^ likes that." She didn't respond but she did press into me once as I traced a circle around her $^$* through her smooth panties. "Let your !&^&^ get wet," I told her but I had a good idea it already was, the crotch of her panties felt slick and it wasn't just the fabric. I told her to lay still as I began rolling the top of her panties down, I pulled at them from either side until they were down to her mid thigh. Again I slid my fingers between her legs and I instantly felt that she was soaking wet, there was no resistance as I moved my finger to dip into her !&^&^. I began rapidly moving my finger so that it would just barely penetrate her and then popping it back out, I could hear the wet smacking sound the motion made, her body was beginning to tense as she focused on the sensation big booty !!%@ I pressed on her hip with my other hand and told her to lay on her tummy, without a word she layed face down in a fluid motion but still without saying anything to me
