Ga door naar hoofdinhoud
Jazz Ultratab C954 Back Cover Replacement
Wat je nodig hebt
  1. Jazz Ultratab C954 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 2 Jazz Ultratab C954 Back Cover Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • On the top of the tablet there are two 1cm screws that hold the back cover on. Locate these screws and remove them using a Phillips head #0 screw driver.
  2. Jazz Ultratab C954 Back Cover Replacement: stap 2, afbeelding 1 van 1
    • You now have to pry the back cover from the touch screen panel. To do this insert a plastic spudger into the seem. Then work your way around the panel until it is free.
    • There are buttons on the top side of the tablet that go through the back cover. The cover must slide up when removed to avoid damaging the buttons.
  3. Jazz Ultratab C954 Back Cover Replacement: stap 3, afbeelding 1 van 1
    • This is what your tablet should look like once the back cover is removed. You are now ready to begin repairing your tablet. Follow the corresponding guide for instructions on repairing major components.
    • To reattach the back cover begin by sliding the cover on making sure the buttons and the speaker are in their designated holes on the back cover. Then attach the two covers by pressing them together until you hear the plastic tabs interlock.
    • With the two screens held together the last step is to put the two 1cm screws on the top of the tablet back in. Your tablet is now ready for use again!
Conclusie
Nicole Nault
413 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-7, Shastany Spring 2015 Lid van UMass Dartmouth, Team 1-7, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G7
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 293
