Ga door naar hoofdinhoud
Jazz UltraTab C1059-HL Speaker Replacement
Wat je nodig hebt
    1. Jazz UltraTab C1059-HL Speaker Replacement, Speaker: stap 1, afbeelding 1 van 2 Jazz UltraTab C1059-HL Speaker Replacement, Speaker: stap 1, afbeelding 2 van 2
      • Start by removing the back panel.
      • Remove the 4 screws holding the device together: two on the left side, and two on the right side.
      • Using a metal spudger, carefully pry open the case.
      • With the screws gone, the case is held together with clips along the outside edge of the aluminum backplate.
      • Undoing these clips can take a bit of force. Be cautious not to damage the plastic edge of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Jazz UltraTab C1059-HL Speaker Replacement: stap 2, afbeelding 1 van 1
      • Place the device on the table with the screen-side down.
      Vraag FixBot
      Voeg opmerking toe
    3. Jazz UltraTab C1059-HL Speaker Replacement: stap 3, afbeelding 1 van 1
      • This is the Speaker.
      • Remove the two black screws.
      Vraag FixBot
      Voeg opmerking toe
    4. Jazz UltraTab C1059-HL Speaker Replacement: stap 4, afbeelding 1 van 1
      • Remove black tape from the wires.
      • Keep this tape, you will need it for reassembly.
      Vraag FixBot
      Voeg opmerking toe
    5. Jazz UltraTab C1059-HL Speaker Replacement: stap 5, afbeelding 1 van 1
      • Using a soldering iron, heat up the spot where the speaker wires connect to the mainboard.
      • Remove Speaker wires when the solder liquifies.
      • Remember to make note of where each wire is connected. When reinstalling the speaker, it is important that the wires are reattached to the same spot.
      Vraag FixBot
      Voeg opmerking toe
    6. Jazz UltraTab C1059-HL Speaker Replacement: stap 6, afbeelding 1 van 1
      • Remove the speaker.
      • Replace the speaker by following these steps in reverse.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tim Poe
361 Reputatie
3 handleidingen geschreven
IUPUI, Team 1-3, Wilson Fall 2015 Lid van IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Leden
72 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 22
Altijd: 323
