Ga door naar hoofdinhoud
Jazz UltraTab C1059-HL Screen Replacement
Wat je nodig hebt
    1. Jazz UltraTab C1059-HL Screen Replacement, Screen: stap 1, afbeelding 1 van 1
      • First step is to remove screws from top and bottom of device.
      Vraag FixBot
      Voeg opmerking toe
    2. Jazz UltraTab C1059-HL Screen Replacement: stap 2, afbeelding 1 van 1
      • Remove the back panel of the device.
      • Be careful not to brake/bend the plastic cover of your device.
      Vraag FixBot
      Voeg opmerking toe
    3. Jazz UltraTab C1059-HL Screen Replacement: stap 3, afbeelding 1 van 1
      • Upon removing the back panel, place the device screen down on the table.
      Vraag FixBot
      Voeg opmerking toe
    4. Jazz UltraTab C1059-HL Screen Replacement: stap 4, afbeelding 1 van 1
      • Remove all data strips attached to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Jazz UltraTab C1059-HL Screen Replacement: stap 5, afbeelding 1 van 3 Jazz UltraTab C1059-HL Screen Replacement: stap 5, afbeelding 2 van 3 Jazz UltraTab C1059-HL Screen Replacement: stap 5, afbeelding 3 van 3
      • Remove the tape around the battery.
      • One of these pieces of tape holds down the battery connection to the mainboard.
      • Use the soldering iron to disconnect these wires.
      • You will need to use a tool to pry off the battery. It will have a good amount of adhesive holding it down.
      • Be cautious not to bend the battery when prying.
      Vraag FixBot
      Voeg opmerking toe
    6. Jazz UltraTab C1059-HL Screen Replacement: stap 6, afbeelding 1 van 1
      • Once the battery is removed, make sure to remove any and all data strips that are attached.
      • Then begin to unscrew the mother board.
      Vraag FixBot
      Voeg opmerking toe
    7. Jazz UltraTab C1059-HL Screen Replacement: stap 7, afbeelding 1 van 1
      • Remove the motherboard chip off of the device.
      Vraag FixBot
      Voeg opmerking toe
    8. Jazz UltraTab C1059-HL Screen Replacement: stap 8, afbeelding 1 van 1
      • Your board should look like this after taking all of the components off the screen panel.
      Vraag FixBot
      Voeg opmerking toe
    9. Jazz UltraTab C1059-HL Screen Replacement: stap 9, afbeelding 1 van 2 Jazz UltraTab C1059-HL Screen Replacement: stap 9, afbeelding 2 van 2
      • Remove the Display Module from the screen cover.
      Vraag FixBot
      Voeg opmerking toe
    10. Jazz UltraTab C1059-HL Screen Replacement: stap 10, afbeelding 1 van 1
      • Now, you can replace your broken or damaged screen!
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Amanda Justiniano
231 Reputatie
2 handleidingen geschreven
IUPUI, Team 1-3, Wilson Fall 2015 Lid van IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Leden
72 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 47
Altijd: 710
