Ga door naar hoofdinhoud
Jazz UltraTab C1059-HL Screen Replacement
Wat je nodig hebt
  1. Jazz UltraTab C1059-HL Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • First step is to remove screws from top and bottom of device.
  2. Jazz UltraTab C1059-HL Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the back panel of the device.
    • Be careful not to brake/bend the plastic cover of your device.
  3. Jazz UltraTab C1059-HL Screen Replacement: stap 3, afbeelding 1 van 1
    • Upon removing the back panel, place the device screen down on the table.
  4. Jazz UltraTab C1059-HL Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove all data strips attached to the motherboard.
  5. Jazz UltraTab C1059-HL Screen Replacement: stap 5, afbeelding 1 van 3 Jazz UltraTab C1059-HL Screen Replacement: stap 5, afbeelding 2 van 3 Jazz UltraTab C1059-HL Screen Replacement: stap 5, afbeelding 3 van 3
    • Remove the tape around the battery.
    • One of these pieces of tape holds down the battery connection to the mainboard.
    • Use the soldering iron to disconnect these wires.
    • You will need to use a tool to pry off the battery. It will have a good amount of adhesive holding it down.
    • Be cautious not to bend the battery when prying.
  6. Jazz UltraTab C1059-HL Screen Replacement: stap 6, afbeelding 1 van 1
    • Once the battery is removed, make sure to remove any and all data strips that are attached.
    • Then begin to unscrew the mother board.
  7. Jazz UltraTab C1059-HL Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the motherboard chip off of the device.
  8. Jazz UltraTab C1059-HL Screen Replacement: stap 8, afbeelding 1 van 1
    • Your board should look like this after taking all of the components off the screen panel.
  9. Jazz UltraTab C1059-HL Screen Replacement: stap 9, afbeelding 1 van 2 Jazz UltraTab C1059-HL Screen Replacement: stap 9, afbeelding 2 van 2
    • Remove the Display Module from the screen cover.
  10. Jazz UltraTab C1059-HL Screen Replacement: stap 10, afbeelding 1 van 1
    • Now, you can replace your broken or damaged screen!
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Amanda Justiniano
231 Reputatie
2 handleidingen geschreven
IUPUI, Team 1-3, Wilson Fall 2015 Lid van IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 452
