Ga door naar hoofdinhoud
Jazz UltraTab C1059-HL Battery Replacement
Wat je nodig hebt
  1. Jazz UltraTab C1059-HL Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • remove the screws at the four corners of the device.
  2. Jazz UltraTab C1059-HL Battery Replacement: stap 2, afbeelding 1 van 2 Jazz UltraTab C1059-HL Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a prying tool to pry the back panel from the tablet chassis. Pry the panel at different locations around the device to separate clips.
  3. Jazz UltraTab C1059-HL Battery Replacement: stap 3, afbeelding 1 van 1
    • Use a soldering iron to remove power cables from battery. The power cable is shown at the corner of the battery in the picture.
  4. Jazz UltraTab C1059-HL Battery Replacement: stap 4, afbeelding 1 van 2 Jazz UltraTab C1059-HL Battery Replacement: stap 4, afbeelding 2 van 2
    • Use a tool to carefully pry battery away from chassis. The battery is attached by an adhesive. Slowly pry battery on the side away from the motherboard.
  5. Jazz UltraTab C1059-HL Battery Replacement: stap 5, afbeelding 1 van 1
    • You have successfully removed the battery. Put new battery in the same location. Solder the supply wires. Reapply tape in original location.
Conclusie
Austen Shields
101 Reputatie
1 Handleiding geschreven
IUPUI, Team 1-3, Wilson Fall 2015 Lid van IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 599
