Ga door naar hoofdinhoud
Jazz UltraTab C1059-HL Antenna Replacement
Wat je nodig hebt
  1. Jazz UltraTab C1059-HL Antenna Replacement, Antenna: stap 1, afbeelding 1 van 1
    • First step is to remove screws from top and bottom of device.
  2. Jazz UltraTab C1059-HL Antenna Replacement: stap 2, afbeelding 1 van 1
    • Remove the back panel of the device.
  3. Jazz UltraTab C1059-HL Antenna Replacement: stap 3, afbeelding 1 van 1
    • Upon removing the back panel, place the device screen down on the table.
  4. Jazz UltraTab C1059-HL Antenna Replacement: stap 4, afbeelding 1 van 1
    • Identify the antenna cover on the top of the device.
  5. Jazz UltraTab C1059-HL Antenna Replacement: stap 5, afbeelding 1 van 1
    • Remove the two screws holding the antenna cover in place.
  6. Jazz UltraTab C1059-HL Antenna Replacement: stap 6, afbeelding 1 van 1
    • Use a prying tool to remove the plastic piece off of the antenna component.
  7. Jazz UltraTab C1059-HL Antenna Replacement: stap 7, afbeelding 1 van 1
    • Identify the antenna component as the gray cable that comes out of the plastic cover.
  8. Jazz UltraTab C1059-HL Antenna Replacement: stap 8, afbeelding 1 van 1
    • Remove all of the adhesive tape pieces off of the antenna cable.
  9. Jazz UltraTab C1059-HL Antenna Replacement: stap 9, afbeelding 1 van 1
    • Once all of the adhesive tape has been removed. Pull out the antenna component.
  10. Jazz UltraTab C1059-HL Antenna Replacement: stap 10, afbeelding 1 van 1
    • The antenna will be attached to the chip in your device. Be careful not to pull off.
    • Solder of the wire that is connected to the chip in order to be able to remove the antenna component.
    • Once this is done, you can replace your old antenna with a new one!
Conclusie
Amanda Justiniano
231 Reputatie
2 handleidingen geschreven
IUPUI, Team 1-3, Wilson Fall 2015 Lid van IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 201
