Ga door naar hoofdinhoud
Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement
Wat je nodig hebt
  1. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Battery: stap 1, afbeelding 1 van 2 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
  2. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: stap 2, afbeelding 1 van 1
    • Tilt device so that batteries slide out.
  3. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Lens: stap 3, afbeelding 1 van 3 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Lens: stap 3, afbeelding 2 van 3 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Lens: stap 3, afbeelding 3 van 3
    • Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
    • Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
  4. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: stap 4, afbeelding 1 van 3 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: stap 4, afbeelding 2 van 3 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: stap 4, afbeelding 3 van 3
    • Make sure to take care in prying case apart. There are two wires (one red and one black) that could get disconnected from the motherboard.
    • Gently seperate the two halves of the device.
    • To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
    • When the screws have been fully unscrewed, use the tweezers to remove them from the device.
  5. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: stap 5, afbeelding 1 van 3 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: stap 5, afbeelding 2 van 3 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: stap 5, afbeelding 3 van 3
    • Turn the device over so that the lens is facing downward. Take care not to detach any wires during this step.
    • Locate and unscrew the two 5.6 mm Phillips #00 screws holding the lens to the board.
    • Turn the device back over so that the lens faces upward, and carefully remove the lens from the board.
  6. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Board/Microphone/Battery Compartment: stap 6, afbeelding 1 van 3 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Board/Microphone/Battery Compartment: stap 6, afbeelding 2 van 3 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Board/Microphone/Battery Compartment: stap 6, afbeelding 3 van 3
    • To remove the microphone from the case, insert the tip of the spudger under the microphone's edge and pry it away from the case.
  7. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: stap 7, afbeelding 1 van 3 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: stap 7, afbeelding 2 van 3 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: stap 7, afbeelding 3 van 3
    • Unscrew the three 5.6 mm Phillips #00 screws that connect the battery compartment to the case.
    • Remove the battery compartment from the case of the device.
Conclusie
Katelyn Fry
1 Reputatie
7 handleidingen geschreven
Clemson, Team 12-3, Benson Spring 2013 Lid van Clemson, Team 12-3, Benson Spring 2013
CLEM-BENSON-S13S12G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 14
Altijd: 312
