Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Jawbone Big Jambox Outer Case Replacement
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. Jawbone Big Jambox Outer Case Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
    • Due to interior clips holding the end caps in place, use caution when applying force.
  2. Jawbone Big Jambox Outer Case Replacement: stap 2, afbeelding 1 van 3 Jawbone Big Jambox Outer Case Replacement: stap 2, afbeelding 2 van 3 Jawbone Big Jambox Outer Case Replacement: stap 2, afbeelding 3 van 3
    • Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
    • You may want to only take the tabs half way off to avoid re-gluing when reassembling.
    • Use a screwdriver to remove the three T6, 7.0 mm screws under each rubber tab.
    • Because the screws are a different length, set the screws aside.
  3. Jawbone Big Jambox Outer Case Replacement: stap 3, afbeelding 1 van 3 Jawbone Big Jambox Outer Case Replacement: stap 3, afbeelding 2 van 3 Jawbone Big Jambox Outer Case Replacement: stap 3, afbeelding 3 van 3
    • With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
    • Unscrew indicated T6 9.7 mm screws.
    • Gently loosen the tabs from their anchor points so the bottom may be removed.
    • Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
  4. Jawbone Big Jambox Outer Case Replacement: stap 4, afbeelding 1 van 1
    • Pry up the bottom panel by lifting from the device.
    • Pull the bottom up. This may take a bit of force as the bottom is glued to device.
    • Once removed, the battery will now be visible.
  5. Jawbone Big Jambox Outer Case Replacement: stap 5, afbeelding 1 van 2 Jawbone Big Jambox Outer Case Replacement: stap 5, afbeelding 2 van 2
    • Before unscrewing, take a picture of the top view. That way, when you're reassembling the device, you'll know the orientation of the metal grounding plates.
    • Unscrew the eight indicated T6 9.8 mm screws. Remove metal grounding plates.
  6. Jawbone Big Jambox Outer Case Replacement: stap 6, afbeelding 1 van 1
    • Once all eight screws are removed, pry the sides of the Jambox to lift the body from it's shell.
  7. Jawbone Big Jambox Outer Case Replacement: stap 7, afbeelding 1 van 1
    • With the battery facing forward, remove the three indicated T6 9.5 mm screws.
    • Once the screws are removed, lift up the small plastic plate, revealing the auxiliary board underneath.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Abby Cybula
1.913 Reputatie
2 handleidingen geschreven
Cal Poly, Team 24-5, Lancaster Spring 2015 Lid van Cal Poly, Team 24-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G5
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 364
