Inleiding
This is a guide to remove the button panel, which must be removed to gain access to the circuit board and remove the auxiliary board.
Wat je nodig hebt
Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
Unscrew indicated T6 9.7 mm screws.
Gently loosen the tabs from their anchor points so the bottom may be removed.
Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
Turn the Jambox so that the button panel is visible.
Remove the indicated screws, T6 9.6 mm.
