Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide outlines the steps to remove and replace the battery in Big Jambox. Guide includes gaining access to the auxiliary board to unplug battery.
Wat je nodig hebt
Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
Unscrew indicated T6 9.7 mm screws.
Gently loosen the tabs from their anchor points so the bottom may be removed.
Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
Remove the indicated T6, 7.4mm screw holding the auxiliary board in place.
Carefully lift the circuit board up and off to the side.
64 andere personen hebben deze handleiding voltooid.
30 opmerkingen
Where do I buy the battery.
http://www.ebay.com/itm/322588700358?ul_... :Here is someone who made and sell the battery for Jambox and Big Jambox, i hope this could be helpful
Lin -
Where do I go to purchase a battery?
