Inleiding
This guide outlines the steps to remove and replace the battery in Big Jambox. Guide includes gaining access to the auxiliary board to unplug battery.
Wat je nodig hebt
Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
Remove the three T6, 7.0 mm screws under each rubber tab.
I used rubber cement to reattach the pads. That will hold them in place and be easily removable in future.
With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
Unscrew indicated T6 9.7 mm screws.
Gently loosen the tabs from their anchor points so the bottom may be removed.
Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
Pry up the bottom panel by lifting from the device.
Pull the bottom up. This may take a bit of force as the bottom is glued to device.
Once removed, the battery will now be visible.
Remove the indicated T6, 7.4mm screw holding the auxiliary board in place.
Carefully lift the circuit board up and off to the side.
64 andere personen hebben deze handleiding voltooid.
30 opmerkingen
Where do I buy the battery.
http://www.ebay.com/itm/322588700358?ul_... :Here is someone who made and sell the battery for Jambox and Big Jambox, i hope this could be helpful
Lin -
Where do I go to purchase a battery?
http://www.ebay.com/itm/JAWBONE-Big-JAMB... Here is someone who made and sell the battery for Jambox and Big Jambox, i hope this could be helpful
I have been a tech for over 40 years. You did an outstanding job with description and great photos. Tech's are not know for this.
This looks like a great guide. However, I've had this speaker less than a year and my battery should not be needing replacement. It won't hold a charge and I've tried all the other troubleshooting ideas except taking it apart, unconnecting and then connecting again.
Hey John...me too! I called their customer service and because my Jambox is just over 1 year old they said there was nothing they could do. They suggested I buy a new one!
I tried their suggestions: https://jawbone.com/support/articles/000...
No luck...it works fine if plugged in, but has to stay that way.
let us know if you find any answers! Thanks!
deb -
Here's what worked for me.
1) I followed all of the instructions above
2) I simply unplugged the battery,
3) plugged in the electrical charger cord
4) powered on the Jambox. it worked just fine
5) powered it off,
6) plugged the battery back in (white and red wires) and let it charge
7) put the jambox back together
Does anyone know what type of screwdriver to use for the screws under the rubber circles?
T6 same as others. don’t be surprised if the machine thread nut that is molded to inside doesn’t break off i just tighten them back with cover off and put some epoxy glue as i reattached cover
Edward M -
Was Hoping to Find this Process for JawBone Original -
I have two of these now maybe 5 yrs old - and both need new batteries.
But from what I see here - Looks like it'll be battle of Discovery -
Then figure out where to get the batteries.
In the meantime I received new Pelican 1050 case to keep them in
along with cords, etc. Perfect fit - bullet proof protection,
and playing music, just pop open the lid,, sounds great.
My speaker doesn't work at all with USB charge nor regular charge.
Is that still battery? I am not sure about that because if it was the battery by having it plugged in it should work but here I have it plugged in and it doesn't work that makes me think that it's not the battery what do you guys think
I got a replacement battery for JAWBONE Big from ebay, it works great! here is the link:
The metal grounding clip fell off before I could see how it’s attached. I’m looking at Step #3 and the metal grounding clip indicated in orange, but the picture is a bit fuzzy and I can’t tell how it’s attached. Can anybody attach a photo or describe how it’s supposed to be attached? Thanks in advance!
Here is where you can find a good battery. https://www.ebay.com/itm/192329093200
Many thanks for these clear instructions. Did the replacement with a battery from AliExpress, now my speaker has new life.
On the button side, beware the Earthing tab that sits above the charging port. You can tell when you re-assemble as it is the only tab that doesn’t have any paint on it. Also - top tip, when putting on the button end panel, keep your finger pushed on the BT pairing button to make sure it goes in the appropriate hole. I didn’t do this the first time, and the peg missed the hole and made the button stand out (and was unusable). In my frustration to remove the end panel again - I broke one corner :(
Great Tutorial, thank you.
Very simple install, a couple different options on Amazon come with the screw driver needed for under $30. Compared to how much the speaker cost new, this simple repair is well worth the time, even for a busy person. Thank you for the write up!
easy peasy… thanks for the help!
Take a picture of the bottom of the big jambox so you can put the rubber feet back into the same location/orientation. Put the jawbone logo on the front of the big jambox in the photo so you know which side is the front/back. The rubber feet ONLY fit in the same spot that they came from - they have unique holes on the bottom of the feet that only fit into their respective locations on the case. The photo in this guide of the bottom of the big jambox does NOT have the feet in the correct locations. Thanks for the guide - 2023 putting new battery in to keep the tunes going!
What is the battery? Horrible to have to ask this really. Why is everything so hidden and coded? I am sick to death of this secretive nonsense.
Please tell us what the battery is. These silly comments giving an ebay address are ALL EXPIRED and of no use - just adding frustration. If you had given an image in the first place then we could simply install one and get over this automated trash. Expose the criminals who are wasting the earth's resources through greed. I suspect that two 18560 batteries are inside this trash made in usa.
Really helpful guide, thanks! Living in Alaska, I can't have replacement battery packs shipped from Amazon, so I had to replace the bad 18650 cells in the old/bad pack with new ones previously obtained for another project. That was pretty straightforward, but... should you do it... be aware that the battery module circuit board inhibits current flow until it has been plugged into the motherboard, and then energized with external power. And then it all fires up and works! Weird but true, so don't despair when you take your VOM to the disconnected plug and it looks dead.
Can someone show the clips please in a photo?
kenneth keen - Antwoord
