Ga door naar hoofdinhoud
Jam Voice Speaker Replacement
Wat je nodig hebt
  1. Jam Voice Speaker Replacement, Hard Mesh Cover: stap 1, afbeelding 1 van 2 Jam Voice Speaker Replacement, Hard Mesh Cover: stap 1, afbeelding 2 van 2
    • Insert the plastic opening tool underneath the mesh top.
    • Pry the cover open.
    • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
  2. Jam Voice Speaker Replacement, Motherboard: stap 2, afbeelding 1 van 1
    • Remove the four 7mm Phillips screws from the plastic cover.
  3. Jam Voice Speaker Replacement: stap 3, afbeelding 1 van 2 Jam Voice Speaker Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 5mm Phillips screws that hold down the speaker in place.
    • Remove the two 6mm Phillips screws that hold down the plastic casing.
  4. Jam Voice Speaker Replacement: stap 4, afbeelding 1 van 1
    • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
    • Pull the speaker up and out.
  5. Jam Voice Speaker Replacement: stap 5, afbeelding 1 van 3 Jam Voice Speaker Replacement: stap 5, afbeelding 2 van 3 Jam Voice Speaker Replacement: stap 5, afbeelding 3 van 3
    • Remove the four 7mm Phillips screws to expose the motherboard.
  6. Jam Voice Speaker Replacement: stap 6, afbeelding 1 van 1
    • After removing all of the screws from the plastic cover, remove it by pulling up and out.
    • Be careful not to pull and damage any of the wires.
  7. Jam Voice Speaker Replacement: stap 7, afbeelding 1 van 2 Jam Voice Speaker Replacement: stap 7, afbeelding 2 van 2
    • Remove the three 5mm Phillips screws that hold the motherboard in place.
    • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
  8. Jam Voice Speaker Replacement, Speaker: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to pull out the speaker's wire from the motherboard.
    • Use tweezers to pull out the battery's wire from the motherboard.
    • The speaker's connection point is opposite the battery's connection point.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alexander Buck
358 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 429
