Ga door naar hoofdinhoud
Inleiding
If the lights on the board aren’t working, the buttons on aren’t responsive, or Bluetooth is no longer functioning correctly, you may need to replace the motherboard. This guide will give you step-by-step instructions on how to replace the motherboard on the Jabra Speak 510.
  1. Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws. Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Remove the six 20 mm T6 screws from the bottom of the device.
    • Remove the six 20 mm T6 screws from the bottom of the device.
    Remove the screws using T6 Torx screwdriver.
    Taha Asad - Antwoord
  3. Remove the back plate and the grey foam underneath. Remove the back plate and the grey foam underneath.
    • Remove the back plate and the grey foam underneath.
  4. Use a small, pointed metal spudger to  release the plastic tabs connecting the faceplate to the bottom of the speaker. A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening  the device. Slowly flip the device open like a clam shell.
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
    The hooks on the plastic tabs point inwards. You can see the counterpart of a hook on the 2nd picture on the left of the battery.
    I released the hooks by pushing the plastic pads outwards, gently pulling a flat-head screwdriver towards the center. It is necessary to pull the screwdriver ca. 3mm back from the maximum possible depth (otherwise you would push the counterpart outwards, instead of the plastic pad).
    Franz - Antwoord
  5. Using the T6 Torx Screwdriver, remove the four (4mm) screws. Using the T6 Torx Screwdriver, remove the four (4mm) screws.
    • Using the T6 Torx Screwdriver, remove the four (4mm) screws.
  6. After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
    • After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
    Hi.
    Perhaps it could seem strange but I need to reduce the Bluetooth range so the device doesn't connect to my cellphone when I'm more tan three meters from it. Where is the BT antenna? It's the Golden ring in the outer of the MB maybe? What could be the better way to reduce the BT range?.
    Thanks.
    Jose E - Antwoord
  7. Peel off the white adhesive to desolder the connections underneath. Desolder the wires connected to the motherboard.
    • Peel off the white adhesive to desolder the connections underneath.
    • Desolder the wires connected to the motherboard.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
    • Keep track of where the wires are connected. When re-assembling you will have to connect the wires in the correct spot.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jordan Murphy
588 Reputatie
3 handleidingen geschreven
IUPUI, Team 2-3, Harley Spring 2016 Lid van IUPUI, Team 2-3, Harley Spring 2016
IUPUI-HARLEY-S16S2G3
4 Leden
4 handleidingen geschreven
Great walk-through... thanks
Walaa Maher - Antwoord
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
Thomas Sprenger - Antwoord
Hello
Where I can buy the motherboard replacement?
Regards
Lobo Gris - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 99
Altijd: 4,265
