Ga door naar hoofdinhoud
Jabra Freeway Speaker Replacement
Wat je nodig hebt
  1. Jabra Freeway Speaker Replacement, Front Panel: stap 1, afbeelding 1 van 3 Jabra Freeway Speaker Replacement, Front Panel: stap 1, afbeelding 2 van 3 Jabra Freeway Speaker Replacement, Front Panel: stap 1, afbeelding 3 van 3
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
  2. Jabra Freeway Speaker Replacement: stap 2, afbeelding 1 van 3 Jabra Freeway Speaker Replacement: stap 2, afbeelding 2 van 3 Jabra Freeway Speaker Replacement: stap 2, afbeelding 3 van 3
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
  3. Jabra Freeway Speaker Replacement: stap 3, afbeelding 1 van 3 Jabra Freeway Speaker Replacement: stap 3, afbeelding 2 van 3 Jabra Freeway Speaker Replacement: stap 3, afbeelding 3 van 3
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Speaker Replacement, Speaker: stap 4, afbeelding 1 van 2 Jabra Freeway Speaker Replacement, Speaker: stap 4, afbeelding 2 van 2
    • Gently lift the speaker out of the device using the spudger.
    • The speaker is not fixed in place, and therefore very little force is necessary to remove this component.
  5. Jabra Freeway Speaker Replacement: stap 5, afbeelding 1 van 1
    • Desolder the two wires connecting to the speaker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alec Wilson
741 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 4-8, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-8, Catania Fall 2016
UMASSD-CATANIA-F16S4G8
2 Leden
6 handleidingen geschreven
Één opmerking
This guide is missing something. It is titled Speaker Replacement not just removal. Useful information to complete the replacement of a faulty speaker would include where to find a replacement part or at least a part number to search for. Removing the speaker without replacing it with another is of little use. But thank you for your time and effort.
Jssamp - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 959
