Ga door naar hoofdinhoud
Jabra Elite 85h Microphone Replacement
Wat je nodig hebt
  1. Jabra Elite 85h Microphone Replacement, Ear Cushion: stap 1, afbeelding 1 van 3 Jabra Elite 85h Microphone Replacement, Ear Cushion: stap 1, afbeelding 2 van 3 Jabra Elite 85h Microphone Replacement, Ear Cushion: stap 1, afbeelding 3 van 3
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Microphone Replacement, Speaker: stap 2, afbeelding 1 van 3 Jabra Elite 85h Microphone Replacement, Speaker: stap 2, afbeelding 2 van 3 Jabra Elite 85h Microphone Replacement, Speaker: stap 2, afbeelding 3 van 3
    • The foam inserts and backing tape are very delicate. Take your time when removing them, and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Microphone Replacement: stap 3, afbeelding 1 van 3 Jabra Elite 85h Microphone Replacement: stap 3, afbeelding 2 van 3 Jabra Elite 85h Microphone Replacement: stap 3, afbeelding 3 van 3
    • Repeat the previous steps for the other side, removing the foam inserts with care.
  4. Jabra Elite 85h Microphone Replacement: stap 4, afbeelding 1 van 1
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Microphone Replacement: stap 5, afbeelding 1 van 1
    • Repeat the previous step for the other side, removing the four T6 screws.
  6. Jabra Elite 85h Microphone Replacement: stap 6, afbeelding 1 van 1
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
  7. Jabra Elite 85h Microphone Replacement, Microphone: stap 7, afbeelding 1 van 2 Jabra Elite 85h Microphone Replacement, Microphone: stap 7, afbeelding 2 van 2
    • Remove the four screws attaching the circuit boards to the headphone enclosure.
    • The microphone is located on the lower circuit board.
  8. Jabra Elite 85h Microphone Replacement: stap 8, afbeelding 1 van 3 Jabra Elite 85h Microphone Replacement: stap 8, afbeelding 2 van 3 Jabra Elite 85h Microphone Replacement: stap 8, afbeelding 3 van 3
    • Remove the circuit boards from the headphone enclosure.
    • Carefully lift the bar located on the lower circuit board that contains the 24-pin ribbon cable. Remove the cable.
Conclusie
If the microphone on your Jabra Elite 85h is not working, replacement could be an appropriate solution.
Ryan Callaghan
693 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 3-4, Petersen Spring 2023 Lid van UMass Dartmouth, Team 3-4, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G4
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 51
Altijd: 608
