Inleiding
Without the speaker, the speakerphone would be useless! This guide will tell you step-by-step how to remove and replace a faulty speaker.
Wat je nodig hebt
Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
Pull the tool toward the back of the device to pry it open.
Repeat this process over all edges of the device.
first remove the 4 rubber feet from the back and UNSCREW the 4 screws under those rubber feet...
Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece.
5 opmerkingen
Is this a fairly standard speaker? With radio shack dead, can you suggest a source? Any specs? Yhanks
Did you ever find a speaker for your jabra cruiser?
halo
where i can get the new speaker for jabra cruiser 2?
simple speaker in electronic parts shop 8ohm diameter 35mm price 1.2 €
Note that revisions exist which have no adhesive applied, in which case this step can be skipped. Also remeber to removed the four screws hidden underneath the rubber feet on the back of the unit.
Mobi - Antwoord
