Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Without the speaker, the speakerphone would be useless! This guide will tell you step-by-step how to remove and replace a faulty speaker.
  1. Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • iOpener Instructions
  2. Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Open up the device by pulling the front plate straight up from the back plate.
    • Open up the device by pulling the front plate straight up from the back plate.
  4. OPEN ALLE TABBLADEN
    RAM-upgradekits voor Mac
    Koop kits
    Genoeg RAM
    voor al je tabbladen
    Koop kits
  5. Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece. Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece.
    • Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece.
  6. Using the PH000, unscrew the two 5.5mm screws attaching the speaker to the front plate.
    • Using the PH000, unscrew the two 5.5mm screws attaching the speaker to the front plate.
    • The screwdriver sizes are located on the sides of their heads.
  7. Gently pull the black and red wires away from the back plate to remove the speaker.
    • Gently pull the black and red wires away from the back plate to remove the speaker.
  8. Carefully pull the wires away from the speaker, detaching them from the adhesive, while keeping the ends intact. Carefully pull the wires away from the speaker, detaching them from the adhesive, while keeping the ends intact.
    • Carefully pull the wires away from the speaker, detaching them from the adhesive, while keeping the ends intact.
Conclusie
Spartacus
588 Reputatie
5 handleidingen geschreven
Baylor, Team 8-13, Williams Fall 2014 Lid van Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
3 Leden
Is this a fairly standard speaker? With radio shack dead, can you suggest a source? Any specs? Yhanks
Brucereno2 - Antwoord
Did you ever find a speaker for your jabra cruiser?
Scot Tetreault -
halo
where i can get the new speaker for jabra cruiser 2?
Frantisek Fridrich - Antwoord
simple speaker in electronic parts shop 8ohm diameter 35mm price 1.2 €
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,577
