Ga door naar hoofdinhoud
Jabra CRUISER2 Motherboard Replacement
Wat je nodig hebt
  1. Jabra CRUISER2 Motherboard Replacement, Front Plate: stap 1, afbeelding 1 van 1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • Instructies voor de iOpener
  2. Jabra CRUISER2 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 2 Jabra CRUISER2 Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
  5. Jabra CRUISER2 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
    • The names of the screwdriver heads are listed on the sides of each head.
  6. Jabra CRUISER2 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the motherboard from the device by lifting it up from the back plate.
Conclusie
Spartacus
636 Reputatie
5 handleidingen geschreven
Baylor, Team 8-13, Williams Fall 2014 Lid van Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 762
