Ga door naar hoofdinhoud
Jabra CRUISER2 Battery Replacement
Wat je nodig hebt
  1. Jabra CRUISER2 Battery Replacement, Front Plate: stap 1, afbeelding 1 van 1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • Instructies voor de iOpener
    Note that revisions exist which have no adhesive applied, in which case this step can be skipped. Also remeber to removed the four screws hidden underneath the rubber feet on the back of the unit.
    Mobi - Antwoord
  2. Jabra CRUISER2 Battery Replacement: stap 2, afbeelding 1 van 1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
    first remove the 4 rubber feet from the back and UNSCREW the 4 screws under those rubber feet...
    Bob Engelman - Antwoord
  3. Jabra CRUISER2 Battery Replacement: stap 3, afbeelding 1 van 1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Battery Replacement, Motherboard: stap 4, afbeelding 1 van 2 Jabra CRUISER2 Battery Replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
  5. Jabra CRUISER2 Battery Replacement: stap 5, afbeelding 1 van 1
    • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
    • The names of the screwdriver heads are listed on the sides of each head.
  6. Jabra CRUISER2 Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the motherboard from the device by lifting it up from the back plate.
  7. Jabra CRUISER2 Battery Replacement, Battery: stap 7, afbeelding 1 van 1
    • Desolder the battery from the back of the motherboard using the heated soldering iron.
    • You can find instructions to desolder the battery here. Hoe moet je (de-)solderen?.
    In my case, there is 4 screws to remove before Step 2. Screws are hidden under the rubber stamp.
    ch4 - Antwoord
Conclusie
5 andere personen hebben deze handleiding voltooid.
Spartacus
636 Reputatie
5 handleidingen geschreven
Baylor, Team 8-13, Williams Fall 2014 Lid van Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
3 Leden
5 opmerkingen
what are the battery spec. that are used , for the replacement battery?
michael moody - Antwoord
i agree with Michael above , the “fix” here is pretty useless without even the physical dimensions of the battery , or removing the tape obscuring the numbers on the existing battery, so we might have some hope of referencing one before tearing apart a device and having it sit while a replacement battery is coming ,,,, remember some of us live in very remote areas where it takes quite a while to get parts
bari - Antwoord
Original Battery Specifications
Rechargeable Lithium-ion Polymer cell AHB723938
Typical Capacity 1200mAh at 0.2C mA Discharge
Charging Voltage 4.2 V
Typical Voltage 3.8 V
Charging Method Constant Current/Constant Voltage (CC/CV)
Cut-off Discharge Voltage 3.0V
Max. Discharge Current 2.0C mA
Max. Charge Current 1.0C mA
Cycle Life > 300 cycles at 0.5C mA Charge/Discharge
Operating Temperature for Standard Charge 0℃ to 45℃
Operating Temperature for Discharge -20℃ to 60℃
Storage Temperature -20℃ to 60℃
Energy Density Volumetric Energy Density (Wh/L) 427
Energy Density Gravimetric Energy Density (Wh/Kg) 182
Weight of Bare Cell Approx. 25.0g
Initial Internal Impedance < 81mΩ
Measures approx 35mm x 37mm
Mark Pritchard - Antwoord
Also, in step 6, if you look closely at the picture you will see that the author has all but ruined the device by prying from the wrong side, and has pulled the board connector off the board. Pry GENTLY from the front where it connects to the other board so the connector disconnects instead of prying it off the board and having to resolder it.
I found a battery on Amazon that works for this application and fits in the case. The one I ordered was called “smavco Bundle SRP603443 Battery for ASTRO A50 Plus Micro USB Cable, 800mAh”. It will not have as much battery run-time as the original 1200 mAh, but it is the correct voltage and physical size, and is the only one I have found that comes close. The last 4 digits tells you the physical size of the battery, 34mm x 43mm in this case. The original was 39mm x 38mm, so this one is really close to the same physical size. If the battery is much longer than the original it won’t fit, so be careful if you order a different battery. Also, the Jabra Cruiser 2 will NOT work with the battery removed, so you can’t just pull the battery and use it plugged in.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 23
Altijd: 7,403
