Ga door naar hoofdinhoud
JYX-S55 Motherboard Replacement
Wat je nodig hebt
  1. JYX-S55 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the six screws around the perimeter of the top panel of the machine using a 2.5 mm flathead screwdriver.
  2. JYX-S55 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Grip the top panel with your thumb at the bottom and fingers around the top. Lift the panel until it comes loose.
  3. JYX-S55 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Move the top panel backwards and away from you. Let the panel hang down behind the machine, as this will allow you to have access to the components within the machine.
  4. JYX-S55 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the screws on the left and right side of the motherboard using a JIS #1 screwdriver.
    • It's important to keep these screws separate from the ones unscrewed from the top of the panel. This is so both sets of screws won't get mixed up.
  5. JYX-S55 Motherboard Replacement: stap 5, afbeelding 1 van 3 JYX-S55 Motherboard Replacement: stap 5, afbeelding 2 van 3 JYX-S55 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Detach the red and white bricks plugged into the motherboard.
    • This should allow the motherboard to be completely unattached from the device, and ready to handle.
    • Swap the current motherboard with the new replacement part. Then, plug the white brick into the port on the right of the replacement motherboard, and the red brick back in to the center port.
Conclusie
Sarah Iceman
445 Reputatie
2 handleidingen geschreven
Marist, Team 1-5, Chaterdon Spring 2023 Lid van Marist, Team 1-5, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G5
3 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 52
Altijd: 908
