Ga door naar hoofdinhoud
JVC KW-V820BT Driver Side Panel Removal and Replacement
Wat je nodig hebt
  1. JVC KW-V820BT Driver Side Panel Removal and Replacement, Front Panel Assembly: stap 1, afbeelding 1 van 3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Front Panel Assembly: stap 1, afbeelding 2 van 3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Front Panel Assembly: stap 1, afbeelding 3 van 3
    • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
  2. JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 2, afbeelding 1 van 2 JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 2, afbeelding 2 van 2
    • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
  3. JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 3, afbeelding 1 van 3 JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 3, afbeelding 2 van 3 JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 3, afbeelding 3 van 3
    • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
  4. JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 4, afbeelding 1 van 1
    • Gently remove the front panel from the steel enclosure.
  5. JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 5, afbeelding 1 van 3 JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 5, afbeelding 2 van 3 JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 5, afbeelding 3 van 3
    • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
    • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
  6. JVC KW-V820BT Driver Side Panel Removal and Replacement, Top Panel Removal: stap 6, afbeelding 1 van 3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Top Panel Removal: stap 6, afbeelding 2 van 3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Top Panel Removal: stap 6, afbeelding 3 van 3
    • Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
    • Remove the top panel.
  7. JVC KW-V820BT Driver Side Panel Removal and Replacement, Disc Drive: stap 7, afbeelding 1 van 1
    • After removing all screws and top panel, lift up disc drive from steel enclosure.
  8. JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 8, afbeelding 1 van 1
    • Turn over the disc drive to expose the connector.
    • Gently remove the ribbon cable from the ZIF on the circuit board using the metal spudger.
  9. JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 9, afbeelding 1 van 3 JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 9, afbeelding 2 van 3 JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 9, afbeelding 3 van 3
    • Gently pull to remove the electrical connector from disc drive.
  10. JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 10, afbeelding 1 van 2 JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 10, afbeelding 2 van 2
    • Remove 2 pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
  11. JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 11, afbeelding 1 van 2 JVC KW-V820BT Driver Side Panel Removal and Replacement: stap 11, afbeelding 2 van 2
  12. JVC KW-V820BT Driver Side Panel Removal and Replacement, Driver Side Panel Removal and: stap 12, afbeelding 1 van 3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Driver Side Panel Removal and: stap 12, afbeelding 2 van 3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Driver Side Panel Removal and: stap 12, afbeelding 3 van 3
    • Remove the six pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 208
