Inleiding
Sometimes a video will not be able to record audio or it could be muffled or scrambled. If you are sure that the problem lies in the microphone you should replace it. To remove the microphone you will need a Phillips #000 screwdriver, small plastic opener, and metal spudger.
This guide requires removing a lot of screws so it is important to keep track of which screw goes where. All screw heads are Phillips size #000.
Wat je nodig hebt
Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
Remove the 3.1 mm screw.
Remove the three 5.3 mm screws from the back of the camera.
From the inside of the camera remove these six screws.
3.3 mm
3.6 mm
3.1 mm
4.3 mm
4.3 mm
3.7 mm
Remove the three screws securing the microphone housing and camera operation buttons to the frame with the following sizes:
4.3 mm
3.1 mm
4.2 mm
Open the cassette holder to reveal a 2.4 mm screw on the bottom of the camera and remove it.
Make sure the camera operation buttons are positioned completely outside of the camera frame.
Gently lift the microphone housing from the front-bottom side of the camera and remove it from the frame.
Remove the two 1.6 mm screws securing the microphone casing.
Pull off the microphone casing.
Één andere persoon heeft deze handleiding voltooid.
