Ga door naar hoofdinhoud
JVC Adixxion GC-XA1BU Power & Record Button Board Replacement
Wat je nodig hebt
  1. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement, Battery: stap 1, afbeelding 1 van 1
    • Find the side of the camera that looks like this.
  2. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 2, afbeelding 1 van 1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 3, afbeelding 1 van 1
    • While still pushing down on the black switch, slide back the battery cover (see photo for direction).
  4. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 4, afbeelding 1 van 2 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 4, afbeelding 2 van 2
    • Push the cover up to open the battery compartment, and then push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 5, afbeelding 1 van 1
    • You can now take the battery out of the camera.
  6. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement, Battery Cover: stap 6, afbeelding 1 van 1
    • After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
  7. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement, LCD Cover: stap 7, afbeelding 1 van 2 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement, LCD Cover: stap 7, afbeelding 2 van 2
    • Using a 1x1xH1.5 torx screwdriver, remove the 8 screws (5mm headsize / 4mm length) from the corners of both the front and back of the camera (4 screws on each side).
  8. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 8, afbeelding 1 van 1
    • Carefully lift open the camera from the side of the device with the record and play buttons. Then remove the black cover tape by gently peeling it off. Make sure to save this tape as you may need it when you re-assemble the device.
  9. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 9, afbeelding 1 van 3 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 9, afbeelding 2 van 3 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 9, afbeelding 3 van 3
    • Using the tweezers, carefully push up the left and right sides of the cable ribbon clip. Use the tweezers to life up and remove the clip.
  10. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 10, afbeelding 1 van 2 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 10, afbeelding 2 van 2
    • Using the tweezers, carefully remove the ribbon cable by gently grasping it and pulling up.
  11. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 11, afbeelding 1 van 1
    • Turn the camera 180 degrees, and gently remove the glue from the connector as shown in the photo. Make sure you save the glue as you may need it when re-assembling your device.
  12. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 12, afbeelding 1 van 3 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 12, afbeelding 2 van 3 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 12, afbeelding 3 van 3
    • Now take out the connector by pulling the white clip out of the casing (as shown in the photos). This will will disconnect the screen from the main cable, allowing you to attach your new LCD cover.
  13. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement, Battery Housing: stap 13, afbeelding 1 van 2 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement, Battery Housing: stap 13, afbeelding 2 van 2
    • Carefully peel off the glue holding the red and black braided wire down to the circuit board. Then remove the connector by gently pulling it out of its casing. You will want to save this glue as it may come in handy when re-assembling your device.
  14. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 14, afbeelding 1 van 2 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 14, afbeelding 2 van 2
    • Lift up the white ribbon clip and remove the black ribbon by gently pulling it away from the white clip.
  15. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 15, afbeelding 1 van 1
    • Remove the the three Phillips screws (3mm headsize x 2mm length) from the circuit board. After you remove the screws, you can then remove the green circuit board by lifting it up out of the device case. You may want to use the plastic opening tool to get start lifting the circuit board.
  16. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 16, afbeelding 1 van 1
    • Once the circuit board is removed, you will want to remove the Phillips screw (3mm headsize x 2 mm length) near the ribbon cable. ONLY REMOVE THIS ONE SCREW.
  17. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 17, afbeelding 1 van 2 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 17, afbeelding 2 van 2
    • Use the plastic opening tool to gently remove the top cover from the camera. It is glued on, so you may need to work at it to get it to come off.
  18. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 18, afbeelding 1 van 1
    • Once the cover has been removed, you will want to remove the three Phillips screws (2mm headsize x 2mm length) that are underneath.
  19. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 19, afbeelding 1 van 2 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 19, afbeelding 2 van 2
    • Carefully remove both the top and bottom copper strips by gently pulling them off with the tweezers.
  20. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 20, afbeelding 1 van 2 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement: stap 20, afbeelding 2 van 2
    • Now you should be able to gently remove the battery housing out of the device. If you are having difficulty getting the battery housing to come out, you may want to use the plastic opening tool to help get it started.
  21. JVC Adixxion GC-XA1BU Power & Record Button Board Replacement, Power & Record Button Board: stap 21, afbeelding 1 van 3 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement, Power & Record Button Board: stap 21, afbeelding 2 van 3 JVC Adixxion GC-XA1BU Power & Record Button Board Replacement, Power & Record Button Board: stap 21, afbeelding 3 van 3
    • The power and record buttons are glued to the battery housing, so use the plastic opening tool to gently pry off and remove the buttons.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christina Michelle Johnson
1.047 Reputatie
8 handleidingen geschreven
USF Tampa, Team 1-2, Tanski Winter 2015 Lid van USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 14
Altijd: 722
