Ga door naar hoofdinhoud
JVC Adixxion GC-XA1BU Lens (External) Replacement
Wat je nodig hebt
  1. JVC Adixxion GC-XA1BU Lens (External) Replacement, Battery: stap 1, afbeelding 1 van 1
    • Find the side of the camera that looks like this.
  2. JVC Adixxion GC-XA1BU Lens (External) Replacement: stap 2, afbeelding 1 van 1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU Lens (External) Replacement: stap 3, afbeelding 1 van 1
    • While still pushing down on the black switch, slide back the battery cover (see photo for direction).
  4. JVC Adixxion GC-XA1BU Lens (External) Replacement: stap 4, afbeelding 1 van 2 JVC Adixxion GC-XA1BU Lens (External) Replacement: stap 4, afbeelding 2 van 2
    • Push the cover up to open the battery compartment, and then push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU Lens (External) Replacement: stap 5, afbeelding 1 van 1
    • You can now take the battery out of the camera.
  6. JVC Adixxion GC-XA1BU Lens (External) Replacement, Battery Cover: stap 6, afbeelding 1 van 1
    • After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
  7. JVC Adixxion GC-XA1BU Lens (External) Replacement, Lens (External): stap 7, afbeelding 1 van 2 JVC Adixxion GC-XA1BU Lens (External) Replacement, Lens (External): stap 7, afbeelding 2 van 2
    • Using a 1x1xH1.5 torx screwdriver, remove the eight screws (5mm headsize / 4mm length) from the corners of both sides of the camera (4 screws on each side).
  8. JVC Adixxion GC-XA1BU Lens (External) Replacement: stap 8, afbeelding 1 van 2 JVC Adixxion GC-XA1BU Lens (External) Replacement: stap 8, afbeelding 2 van 2
    • Twist the metal ring on the lens to the right and then pull it off.
  9. JVC Adixxion GC-XA1BU Lens (External) Replacement: stap 9, afbeelding 1 van 2 JVC Adixxion GC-XA1BU Lens (External) Replacement: stap 9, afbeelding 2 van 2
    • Use the plastic opening tool to gently pry the lens off of the camera.
Conclusie
Christina Michelle Johnson
1.047 Reputatie
8 handleidingen geschreven
USF Tampa, Team 1-2, Tanski Winter 2015 Lid van USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 Leden
Één opmerking
Where can the lens be purchased at?
Isaac Aguilar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 626
