Ga door naar hoofdinhoud
JD Razor 2000 Shocks Replacement
Wat je nodig hebt
  1. JD Razor 2000 Shocks Replacement, Removing the 1.75" Axle Bolt: stap 1, afbeelding 1 van 3 JD Razor 2000 Shocks Replacement, Removing the 1.75" Axle Bolt: stap 1, afbeelding 2 van 3 JD Razor 2000 Shocks Replacement, Removing the 1.75" Axle Bolt: stap 1, afbeelding 3 van 3
    • Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
    • Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
    • If the left side of the bolt turns while you unscrew the right side, you will need to use a second Allen wrench to prevent it from moving
    • If the bolt does not move at all, or moves very little, try applying a lubricant on as much of the screw as possible and try again in 5 minutes.
    • Carefully pull apart the bolt and bearing from either side of the wheel.
  2. JD Razor 2000 Shocks Replacement, Removing the Wheel: stap 2, afbeelding 1 van 1
    • Grip the bottom of the wheel and gently slide it out.
  3. JD Razor 2000 Shocks Replacement, Removing the Shock's 1.75" Axle Bolt: stap 3, afbeelding 1 van 3 JD Razor 2000 Shocks Replacement, Removing the Shock's 1.75" Axle Bolt: stap 3, afbeelding 2 van 3 JD Razor 2000 Shocks Replacement, Removing the Shock's 1.75" Axle Bolt: stap 3, afbeelding 3 van 3
    • Find the axle bolt behind the shocks. It should look similar to the one used to remove the front wheel.
    • Remove the bolt in the same manner as the wheel. While applying pressure to the left side, unscrew the right using an Allen wrench.
    • If the left side of the bolt rotates when you attempt to unscrew the right, use a second Allen wrench to hold it in place.
    • If the bolt does not turn at all or does not turn easily, apply lubricant to the screw and try again in five minutes.
    • Remove the bolt and bearing and the black rubber stoppers. Remove the metal tube between the bolt.
  4. JD Razor 2000 Shocks Replacement, Removing the Wheel Holder and Shock: stap 4, afbeelding 1 van 2 JD Razor 2000 Shocks Replacement, Removing the Wheel Holder and Shock: stap 4, afbeelding 2 van 2
    • Firmly grasp the metal piece that holds the wheel and gently pull it away.
    • The shocks should fall out naturally by themselves. This is normal and expected. If they do not, gently pull the shocks out of their holders.
    • A metal cylinder is located inside the spring of the shock. Do not lose this.
Conclusie
Kaylan Naicker
255 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-46, Amido Fall 2014 Lid van Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 1,850
