Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
  1. Unlock the quick-release lever by turning the lever from a tightened position. Unlock the quick-release lever by turning the lever from a tightened position.
    • Unlock the quick-release lever by turning the lever from a tightened position.
  2. Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown. Be sure to fasten the opposite side of the screw before unscrewing. Remove the screw and note the order of the parts for reassembly.
    • Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown.
    • Be sure to fasten the opposite side of the screw before unscrewing.
    • Remove the screw and note the order of the parts for reassembly.
  3. Turn the quick-release lever over to reveal an 8mm screw. Use the Phillips #2 screw driver to remove the screw. After removing the screw, the circular latch will be detachable.
    • Turn the quick-release lever over to reveal an 8mm screw.
    • Use the Phillips #2 screw driver to remove the screw.
    • After removing the screw, the circular latch will be detachable.
Conclusie
Shane
384 Reputatie
3 handleidingen geschreven
Cal Poly, Team 4-46, Amido Fall 2014 Lid van Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Leden
8 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 1,803
