Ga door naar hoofdinhoud
JD Razor 2000 Handle Bar Replacement
Wat je nodig hebt
  1. JD Razor 2000 Handle Bar Replacement, Pulling Out the String: stap 1, afbeelding 1 van 3 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: stap 1, afbeelding 2 van 3 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: stap 1, afbeelding 3 van 3
    • Firmly hold the handle bar in place.
    • Grab with one hand the black removable tip of the handle bar and pull it out.
    • Pull out the end of the tied string through the removable tip.
  2. JD Razor 2000 Handle Bar Replacement, Untying the Knot: stap 2, afbeelding 1 van 2 JD Razor 2000 Handle Bar Replacement, Untying the Knot: stap 2, afbeelding 2 van 2
    • Untie the knot at the end of the string.
    • If you let go of the string while its in tension, it may recoil far into the other side of the handle bars. To avoid this, bring the end of the string inward towards the hollow section of the handle bar and then carefully let it go.
  3. JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: stap 3, afbeelding 1 van 2 JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: stap 3, afbeelding 2 van 2
    • Press down firmly on the golden fastening button located on the handle bar being replaced.
    • While still pressing down on the fastening button, slide the handle bar apart from the T Bar.
    • When re-installing the handlebar (after completion of the guide), you may need a pair of needle-nosed pliers to thread the string back through the handlebar.
Conclusie
Kevin Church
297 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-46, Amido Fall 2014 Lid van Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Leden
16 handleidingen geschreven
Één opmerking
Why is the stretchable string for?
dantotford - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 2,027
