Ga door naar hoofdinhoud
JBL Xtreme Speaker Replacement
Wat je nodig hebt
  1. JBL Xtreme Speaker Replacement, Cover: stap 1, afbeelding 1 van 1
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Speaker Replacement: stap 2, afbeelding 1 van 2 JBL Xtreme Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
    MrMindlink - Antwoord
    Yes, the fact needs to be added that two screws need to also be removed to get the cover off. One side snaps off but the other is attached with two screws.
    Terry Kraft - Antwoord
    %#*@^@. I ripped the plastic things apart. Should have red the comments first. &&^&.
    brobarongg - Antwoord
    same here ;D just grabbed some glue and hope it will stick :D
    Patrick Tippner -
    Vorsichtig die Kante hochhebel, wo der Reissverschluss ist. Da ist die Hülle gesteckt. Die andere Seite hat Schrauben die man lösen sollte. Ansonsten zerstört man zu Beginn die Befestigung der einen Seite.
    Roland Bürger - Antwoord
  3. JBL Xtreme Speaker Replacement: stap 3, afbeelding 1 van 2 JBL Xtreme Speaker Replacement: stap 3, afbeelding 2 van 2
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
    Hello Where can I get a replacement cover?? Mine is damaged.
    juan.rey19 - Antwoord
    Did u ever find it they sell the covers?
    jorgetovar698 -
    Careful with this step, my JBL Xtreme case was also held in place by wo little srews !
    Arthur Lecharny - Antwoord
    It feels like you are “breaking” the cover, but in fact it seems to have a kind of “bending point” near the top of the cover by the exterior controls. Watch for the two screws to remove.
    There is two screws holding the cover at its other end beside the plastic snaps
    Nader Belaid - Antwoord
    %#*@! broke one of the little snaps near the 2 screws. still holds tight though.. be careful when pulling them out. Also, don’t forget the screws
    Mike - Antwoord
    Die beiden Schrauben befinden sich jeweils neben den Füßen des Geräts. (Ein Foto von den beiden Schrauben wäre sehr hilfreich!)
    RTFM - Antwoord
  4. JBL Xtreme Speaker Replacement, Bass Radiator: stap 4, afbeelding 1 van 3 JBL Xtreme Speaker Replacement, Bass Radiator: stap 4, afbeelding 2 van 3 JBL Xtreme Speaker Replacement, Bass Radiator: stap 4, afbeelding 3 van 3
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
    This was the most difficult part for me. The screws are pretty tight, I needed a larger screwdriver to get them out.
    A PH1 or PZ1 Philips screw driver worked for me. For re- assembly it helps to place the speaker on the side with the other end facing down. That way you can exert more force. I would start with tightening all screws part way only and when they are all in place tighten them all the way (including the inner screw).
    RTFM -
    Achtung, die Bassstrahler sind mit dem Gehäuse über zwei “Klebedichtungen” verbunden. Diese müssen beim Zusammenbau wieder eingebaut werden.
    Carsten Schultze-Hartmann - Antwoord
    Die Dichtung war bei mir nicht geklebt, sondern in die dafür vorgesehene Rille eingelegt. Sie ist mir beim Entfernen des Bassstrahlers zwar gerissen, ich konnte sie jedoch mit einem spitzen Kunststoffspachtel wieder in die Rille legen. Beim Zusammenbau muss man darauf achten, dass die Dichtung nicht herausrutscht. Am besten die Seite mit der Dichtung nach unten halten.
    RTFM -
  5. JBL Xtreme Speaker Replacement: stap 5, afbeelding 1 van 3 JBL Xtreme Speaker Replacement: stap 5, afbeelding 2 van 3 JBL Xtreme Speaker Replacement: stap 5, afbeelding 3 van 3
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
    where can i buy these parts mate?
    troy yerbury - Antwoord
    Where can I buy the bass radiators independently?
    Daryl Duliep Hernandez - Antwoord
    Ich empfehlen, erst den 7. Schritt auszuführen. So kann anhand der Kabel feststellen welcher Bassstrahler entfernt werden muss!
    I would recommend to do the 7th step first. So can determine, based on the cable, which bass radiator must be removed!
    Android Robo - Antwoord
    Wo kann ich den die Ersatzteile kaufen bassstrahler und ein hochtöner???
    Sven Muelle - Antwoord
    Schritt sieben zuerst ist eine grandiose Idee, erspart einiges an Nerven.
    Benni Basisch - Antwoord
    die Linke Seite wie auf dem Bild ist die richtige. Dahinter findet man die Platine mit dem Anschlussstecker für den Akku. Somit sollte eigentlich 1ne Seite reichen.
    So war es auch bei mir. Nur die linke Seite (von unten gesehen), also die Seite auf der der Zug vom „Reißverschluss“ endet, wenn er geöffnet ist, muss geöffnet werden. Dann kann man sich die Demontage der anderen Seite sparen!
    RTFM -
  6. JBL Xtreme Speaker Replacement, Speaker: stap 6, afbeelding 1 van 2 JBL Xtreme Speaker Replacement, Speaker: stap 6, afbeelding 2 van 2
    • With the radiators removed, locate the ribbon cable indicated in the image.
    • Gently unplug the cable from the motherbord.
  7. JBL Xtreme Speaker Replacement: stap 7, afbeelding 1 van 3 JBL Xtreme Speaker Replacement: stap 7, afbeelding 2 van 3 JBL Xtreme Speaker Replacement: stap 7, afbeelding 3 van 3
    • First, unscrew the eight 12.93mm Phillips head screws indicated in red. These screws hold the two primary speakers in place.
    • Next, remove the four 9.75mm Phillips head screws for the two smaller speakers indicated in blue and the speakers should lift out with little effort.
    • All speakers are connected via the single cable highlighted in the previous step.
    Except the passive subwoofers on each side, I found one of the JBL logo,, outside left, subwoofer plates to be partially loose which resulted in the rattle on low frequencies. Nothing a good glue couldn’t fix.
    Marc van der Bent - Antwoord
Conclusie
15 andere personen hebben deze handleiding voltooid.
Benny Huynh
1.914 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-1, Sullivan Spring 2017 Lid van USF Tampa, Team 1-1, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G1
4 Leden
27 handleidingen geschreven
11 opmerkingen
My speaker won't hold a charge for more then 2 hours? Why is that thanks
Gil Trujillo - Antwoord
where can i buy the speaker of jbl xtreme?
Jeff Cancino - Antwoord
Where can I get replacement speakers for my JBL?
Luis Baca - Antwoord
Where can I get s replacement speaker
etesme -
where can I get parts to fix the speaker?
Dave - Antwoord
Where can i buy bass radiators for my jbl Xtreme?
Francesco Iavernaro - Antwoord
were can u buy the speakers from
emmanuel walker - Antwoord
My jbl extreme speaker has a power but wont play and connect only the battery light indicator is working. What can I do with this? I am dissapointed since I dont use it much
mckhell14 - Antwoord
wanna sell it? if so send me an email on luduncan886@gmail.com
luduncan -
Can you purchase replacement speaker driver for JBL Xtreme anywhere ? Everywhere I am looking, they are not available or sold out.
Chandler Cook - Antwoord
Where can I get replacement speakers for my JBL Extreme?
snoopy_gama - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 95
Altijd: 29,623
