Inleiding
This Guide will help you replace the battery inside a JBL Xtreme Bluetooth Speaker.
Wat je nodig hebt
Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
Yes, the fact needs to be added that two screws need to also be removed to get the cover off. One side snaps off but the other is attached with two screws.
%#*@^@. I ripped the plastic things apart. Should have red the comments first. &&^&.
same here ;D just grabbed some glue and hope it will stick :D
Vorsichtig die Kante hochhebel, wo der Reissverschluss ist. Da ist die Hülle gesteckt. Die andere Seite hat Schrauben die man lösen sollte. Ansonsten zerstört man zu Beginn die Befestigung der einen Seite.
For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
Hello Where can I get a replacement cover?? Mine is damaged.
Did u ever find it they sell the covers?
Careful with this step, my JBL Xtreme case was also held in place by wo little srews !
It feels like you are “breaking” the cover, but in fact it seems to have a kind of “bending point” near the top of the cover by the exterior controls. Watch for the two screws to remove.
There is two screws holding the cover at its other end beside the plastic snaps
Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
This was the most difficult part for me. The screws are pretty tight, I needed a larger screwdriver to get them out.
A PH1 or PZ1 Philips screw driver worked for me. For re- assembly it helps to place the speaker on the side with the other end facing down. That way you can exert more force. I would start with tightening all screws part way only and when they are all in place tighten them all the way (including the inner screw).
RTFM -
Achtung, die Bassstrahler sind mit dem Gehäuse über zwei “Klebedichtungen” verbunden. Diese müssen beim Zusammenbau wieder eingebaut werden.
Die Dichtung war bei mir nicht geklebt, sondern in die dafür vorgesehene Rille eingelegt. Sie ist mir beim Entfernen des Bassstrahlers zwar gerissen, ich konnte sie jedoch mit einem spitzen Kunststoffspachtel wieder in die Rille legen. Beim Zusammenbau muss man darauf achten, dass die Dichtung nicht herausrutscht. Am besten die Seite mit der Dichtung nach unten halten.
RTFM -
Once the screws have been removed, the bass radiator will easily lift free.
where can i buy these parts mate?
Where can I buy the bass radiators independently?
Ich empfehlen, erst den 7. Schritt auszuführen. So kann anhand der Kabel feststellen welcher Bassstrahler entfernt werden muss!
I would recommend to do the 7th step first. So can determine, based on the cable, which bass radiator must be removed!
Wo kann ich den die Ersatzteile kaufen bassstrahler und ein hochtöner???
Schritt sieben zuerst ist eine grandiose Idee, erspart einiges an Nerven.
die Linke Seite wie auf dem Bild ist die richtige. Dahinter findet man die Platine mit dem Anschlussstecker für den Akku. Somit sollte eigentlich 1ne Seite reichen.
So war es auch bei mir. Nur die linke Seite (von unten gesehen), also die Seite auf der der Zug vom „Reißverschluss“ endet, wenn er geöffnet ist, muss geöffnet werden. Dann kann man sich die Demontage der anderen Seite sparen!
RTFM -
Locate the three 9.7mm Phillips head screws inside the zipper compartment and unscrew them.
Lift the zipper panel out of the speaker.
The screw on the left is tough to get at.
Opgelet, de beide scharnierpunten zij in z-vorm (plastic) en kunnen afbreken.
Achtung! Auf der Seite ohne Schrauben sind 2 Klemmen, die man schnell abreißt … daher das Teil nach lösen der Schrauben nicht nach oben wegklappen… sondern versuchen das ganze Teil vorsichtig nach oben zu heben. Ist am Ende aber nicht dramatisch und hält trotzdem.
Under the zipper panel are eight more 9.75mm Phillips head screws. Unscrew them and carefully lift the battery cover.
2 small screws hold this part to the cover. For ease of future handling, remove them and gently pull this part out to release the cover.
These screws are also very tight and easily stripped if not careful. Use a bigger screwdriver.
Auch hier gibt es, wie beim Bassstrahler, eine dünne umlaufende Gummidichtung, die man vorsichtig in die dafür vorhergesehene Rille zurückdrücken sollte. Auch diese Dichtung war bei mir an einer Stelle zerrissen, was aber kein Problem war.
Bei dem mit zwei Schrauben befestigten Teil handelt es sich um den Block mit den weißen LEDs, die den Ladezustand des Akkus anzeigen. Das Licht der LEDs wird durch die in der Fachabdeckung befindlichen transparenten Stifte nach außen geleitet. Die vorsichtige Demontage mithilfe von Kunststoffspachteln hilft sehr bei den weiteren Schritten!
Locate the cable illustrated in this picture.
Needed to use needle nose pliers to reach this plug.
Note which way the plug goes in as it could get turned around.
Indeed, that’s important. The last cable facing towards you is the black one!
RTFM -
I did it by removing the speaker instead of what it shows in the picture!
My plug was glued with some red, waxy stuff - be aware. JBL folks don’t want you to change the battery :D carefully scratch the glue out without damaging the board and you’ll be fine.
Ein Plastikspachtel hilft beim Lösen bzw.. Anheben der am Stecker befindlichen Nut. Auch beim Herausziehen des Steckers aus der Kabeldurchführung zum Akkufach hilft der Spachtel.
Der neue Akku hat bei mir keine Nut. Da ich den Speaker aber überwiegend stationär verwende, glaube ich nicht, dass sich die Verbindung lockern wird - auch ohne Nut.
Beim Entfernen und Wiedereinsetzen des Steckers hat mir eine abgewinkelte Mini-Flachzange sehr geholfen!
Carefully lift the battery free of the device, threading the cable through the hole in the case as you do so.
Thanks for your help. I also changed battery capacity upto 18000 mah. https://youtu.be/dJgoooYk1v8 my work with poor English speaking sorry for
Habe den Akku getauscht,leider blinkt jetzt nur noch die Bluetooth Lampe und ich kann mich mit keinem Gerät mehr verbinden.Koppeln geht,aber nicht mehr verbinden.
Super Anleitung. Konto genau nach Bildern die Box zerlegen und den Akku tauschen. Vielleicht noch ein Hinweis zum kleinen weißen Flachbandkabel am Akkufachdeckel. Es ist für die Akkustands Anzeige. Wie empfohlen habe die Anzeige durch lösen der beiden kleinen Kreuzschrauben entfernt. Das macht das Arbeiten wirklich viel entspannter.
Danke für die schönen Bilder und die Anleitung.
Super Anleitung hat prima geklappt .
Der Ersatzakku ist bei mir nicht gepolstert gewesen. Ich habe zum Fixieren im Gehäuse zwei kurze Streifen Klettband verwendet. Zum Appoltern nach aussen habe ich einen Streifen „Flauschband“ auf die Rückseite des Akkus geklebt. Allerdings musste ich dann bei der Re-Montage des transparenten Deckels vorsichtig sein, und die 8 Schrauben nach und nach anziehen.
88 andere personen hebben deze handleiding voltooid.
43 opmerkingen
I couldn't find the battery specification anywhere in the Internet, so I removed it, easily following the well presented instructions above. The battery has two cells. The label on each cell says Greatpower, model no. GSP0931134, 7.4 volts, 5000 mah, 37Wh, made in China. Overall dimensions are 145mm x 32mm x 19mm (145mm includes a small electronic board where cables from the board connect to the plug.) After an Amazon and Google search, I'm no closer to a replacement. At least the reassembled Xtreme works without a battery with external power. JBL is of no help, either. I'll be looking model airplane stores, as they have every LiPo battery imaginable. In summary, the JBL Xtreme is a short lived unsupported product.
This is kinda late but were there any extra steps for running the speaker without a battery? Since the speaker is not working anymore at all, even with power connected, I would be happy to run it like this but am not sure whether it is really enough to just remove the battery.
So what this means is you have two lithium cells in parallel and those two are in series with another set of two, they are 3.7V nominal each. 2500mAh and 9.25Wh each.
I don't think this is a lipo battery (comes in all shapes and sizes, literally every dimension you could think of). The dimensions given are far too similar to 4 lithium ion 18650 (18x65mm) cells. Probably have +8 8 8- thats two cells with one lying on top of the other and nickel strip is going across the + of both cells and across the - of both cells. The next set of cells will be right behind it so it will look like this
+8 8 8- +8 8 8-
Imagine each o of the 8 is a cell, it was the easiest way to represent cells stacked on top of each other horizontally. The second set of cells are connected together with nickel strip exactly like the first set, putting them in parallel too. Pushing them together like in my "drawing" is what puts them in series (positive to negative). The single white wire on the 5 wire connector is the balance wire that
this &&^&^$^ jbl costumer support service is charging me $110 for battery replacement, and a $30 service charge, it cost half of the speaker price,
Same here in Hungary.
I’ve got a battery issue (a full charge lasts only about 3-4 hours of playback on mid volume) after a little more than 1 year of usage…
110 US dollars for replacement. Nonsense!
That’s what these instructions are for. You’ll pay 25 EUR for a new battery and maybe 5 .. 10 EUR for some tools and you can fix it yourself and have a speaker that is as good as new!
RTFM -
I just buy this one in amazon: https://www.amazon.com/Cameron-Sino-Li-P...
It’s interesting that these are all 5,000 mAh. JBL lists the capacity on their website and on the packaging as 10,000 mAh Capacity.
Does that mean we need to buy two 5000mAh GSP0931134 replacement cells?
The 10,000 mAh figure is wrong. You just need ONE 5000 mAh replacement battery. Actually there are some 5500 mAh models on Amazon as well but I don’t think this will make a big difference. I decided to go for the manufacturer / vendor who gives 3 years of warranty on the replacement battery.
RTFM -
The battery works great for me. I am no expert, but this guide made it easy. I added some info to help other people in the future. My JBL Extreme is cordless again for 10 hours at a time! Thanks!
I found new battery at Battery Clerk.com. http://www.batteryclerk.com/products/jbl...
https://youtu.be/dJgoooYk1v8 increase your JBL Xtreme battery capacity upto 18000 mah playback timings.
Just now 03/07/2018
I changed my Battery 5000mAh GSP0931134 Battery for JBL Xtreme by ++SMAVCO.++
bought it on Amazon..it took me less than 15min. to replaced my extreme. its now back to rock some bass.
-MarkedXIII™
Found one on walmart.com
Work Fine and good quality,
3-5 days delivery,
good price and Work just like OEM.Good Fit.
check it out,
5000mAh GSP0931134 Speaker Battery for JBL Xtreme bluetooth speaker
Hey guys does the Extreme works when u taking the baterry off just with the cable pluged? Cause mine stoped working even with the cable pluged is that still battery has to do something? I had issues with battery but it just not powering on
Yes, it works without batteries.
Hi I’m from Australia, ordered a $38 battery replacement and tool kit off eBay.
Followed this guide which took took me about 45 minutes (some of the screws are real tight or in a $@$* position so I used a larger screwdriver which helped a lot)
removing the clip on the battery inside took me about five minutes to do since I have large hands and could barely fucken work around it.
process was easy and straight forward, very happy with the outcome.
cheers for the write up!
Ist sogar als Handwerker mit den dicksten Fingern zu bewerkstelligen die Nummer. 3 verschiedene Schraubenlängen sind dabei vorhanden. Davon sind 3 Stück Senkschrauben. Man muss schon vom Feldweg kommen um das nicht zu schaffen. Den originalen Akku bekommt man über den Zulieferer von JBL/Kardon auf Nachfrage bei ESCoor GmbH. für 66€ incl Versand. Als einziges Manko bei der Fummelarbeit wäre zu meinen, dass die Gummidichtungen beim Ausbau zerreissen. Diese lassen sich ein wenig umständlich mittels einer heißen Rolladennadel osä. wieder thermisch zusammenfügen und dann noch fummeliger wieder den Spalt einsetzen. Also tief in den Spalt drücken und denn schnell zusammenbauen. Das Argument des ewigen Neukaufens ist somit wieder vom Tisch. Geile Anleitung Danke!!!
Bought a new battery, installed it, the Xtreme still won’t charge. The new battery initally showed 2 LED’s when I initially powered up, and drainedto one flashing red LED. Checked the dc side of the power brick, read 19(+/-) Volts. I did notice a little side-to-side play in the charging connection. To get at it, it appears that I’ll have to disassemble the entire Xtreme to get at the motherboard. I’ll post when it’s done…..
parfait
merci pour ce tutoriel simple et efficace
ma jbl xtrem est comme neuve
merci
Please my question is on the replacement battery, the one on this (JBL Xtreme Battery), if there is anyone here who has used it for more than a year and if it still holds charge. Thanks
Yes mine is still working g great from 2017!
Look at my link above on the battery I bought. Still works great three years later.
I have seen reviews where customers stated that this particular battery you bought(Cameron Sino 5000mAH) goes from %100 to 30% capacity in 6-8 months.
Many thanks to Sylvain and the other technicians involved. If you don't have two left hands, the changing is relatively easy with this very, very good description.
The old (original) battery/akku was always down after a max. of half an hour. Annoying when you want to use the Xtreme mobile. As the other users already announced, the JBL replacement is very, very expensive. So I bought one at Amazon. 5000 mAh for about 30 EUR / 36 USD.
As Gustavo already mentioned, the original cell is marked with 5000 mAh. And it seems, the are two of them installed (in one block). I am now curious how long a battery charge will last. But still better as the old battery. And then I won't use the box as a power bank anymore.
I put four 18650 cells in there, works better than new! ;)
Great idea, how did you do that???
https://www.amazon.com/gp/product/B08R57...
https://www.amazon.com/gp/product/B00F5E...
This battery seems to have the clip necessary to fully connect the battery properly. Will do the repair in a few days. Just waiting on parts. Will explain if this truly worked appropriately after repair and testing.
My battery has deteriorated very rapidly as well, just over a year and I only get a couple of hours, poor quality batteries used in these. Also not possible to even find a replacement here in SA. :(
Merci pour le tuto, a voir si la batterie que j'ai commandé est correcte maintenant !
Step 1 is wrong, as you will end up breaking the plastic clips holding the cover together, (which for reference I have done and later had to figure out how to fix) the speaker needs to be the other way around for you to prop the plastic clips open, so essentially the way it is pictured is upside down.
To be honest, if you go and watch a youtube video especially most popular one you'll be better off.
Step one is totally correct. It just helps to read the entire document (at least until step 3) before disassembling your speaker. I also looked at some videos but I prefer these instructions here!
RTFM -
Thanks for this tutorial! Changing the battery is very easy if we follow your instructions!
I took the opportunity to pass the hull under water to dust off with the result of having almost new speakers....
Gostaria de trocar a cor do tecido do meu jbl xtreme onde comprar
Dank je voor de duidelijke uitleg
Heb de Jbl volledig gedemonteerd volgens de instructiefst, batterij er netjes kunnen uitnemen, nieuwe batterij besteld … en volgende week zien of we het terug in mekaar krijgen. Tot hiertoe : top ….
12 too short
