Ga door naar hoofdinhoud
JBL Xtreme 3 Battery Replacement
Wat je nodig hebt
  1. JBL Xtreme 3 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Begin by placing the speaker with the grooves on the bottom of the device facing towards you.
    • Use a spudger to carefully pry around the seams of the speaker to open and unlatch the outer shell.
    • Use your hands to finish removing the outer case of the device.
  2. JBL Xtreme 3 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the two 10 mm screws.
  3. JBL Xtreme 3 Battery Replacement: stap 3, afbeelding 1 van 2 JBL Xtreme 3 Battery Replacement: stap 3, afbeelding 2 van 2
    • Use a spudger to carefully pry open the latch located above the control button as shown in the photo. Please be careful!!!
    • Remove the speaker from the shell.
  4. JBL Xtreme 3 Battery Replacement: stap 4, afbeelding 1 van 2 JBL Xtreme 3 Battery Replacement: stap 4, afbeelding 2 van 2
    • Turn the device so that the control buttons are facing down.
    • Use a Phillips #1 screwdriver to remove the eight 10 mm screws from the panel.
    • Carefully remove the panel.
  5. JBL Xtreme 3 Battery Replacement: stap 5, afbeelding 1 van 2 JBL Xtreme 3 Battery Replacement: stap 5, afbeelding 2 van 2
    • The battery is connected to a cable. Use gentle force.
    • Use the spudger to carefully pry the battery out.
  6. JBL Xtreme 3 Battery Replacement: stap 6, afbeelding 1 van 3 JBL Xtreme 3 Battery Replacement: stap 6, afbeelding 2 van 3 JBL Xtreme 3 Battery Replacement: stap 6, afbeelding 3 van 3
    • Use the plastic opening tool to press the white notch while simultaneously unplugging the battery connector.
    • Plug in the replacement.
    • Make sure the new battery is secure. Turn on the device to ensure that the battery is connected properly.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Maria
472 Reputatie
3 handleidingen geschreven
Één opmerking
Great guide! Thank you!
dam damo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 176
Altijd: 4,218
