Inleiding
This guide shows you how to remove the bottom plate, this provides access to the subwoofer itself.
Wat je nodig hebt
Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
With all three loosened remove the base!
Note the not equilateral placement of the risers when replacing the base.
17 andere personen hebben deze handleiding voltooid.
11 opmerkingen
No problem!!
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
I think you should add the phrase “JBL Spot” somewhere in this guide. Although I searched the web and iFixit, this guide didn’t come up because I was searching for JBL spot rather than JBL spyro.
Fixed! Even if four years later haha
This was one of the best, especially for travel. You could find room for it in your suit case. It’s very lightweight for the amount of bass and beats you’re getting 36W in days before bluetooth battery speakers. I just found my old one in my parents garage and it working but static-y. ONe of the connection jacks serems to be the issue.
The sound quality was great! But the legs on those little satellites were easy to break so idk personally about traveling with them!
De unde pot procura placa inferioară jbl. SPIRO? "subwoofer speacher satelite"?
I doubt it but perhaps there are 3D files online or you could make your own with any material the screws can pass through!
