Inleiding
When the lights are displaying improperly, usually replacing the LED lights will fix the problem.
Wat je nodig hebt
Use a plastic opening tool to pry around the edges of the circular rubber panel.
Take out the four 9mm black PH0 screws from the top and bottom of the device.
Pull off cap by hand.
The outer casing can now be removed.
Remove the tape around the cables on the top of the device.
Remove the cables by lifting up on the black bracket and then pulling the cable out.
